How to convert a Reference to something useful?
I'm trying to use the PickObjects method and judging by the lack of documentation and examples out there, it's not a good direction to go.  But regardless, it returns an array of References.  So now what?  How can I cast that Reference something useful, like a Wall or Beam?
        Dim pickedObjs As IList(Of Reference) = sel.PickObjects(ObjectType.Element, "Please select objects")
        For Each PO In pickedObjs
            Dim CurObj As Element = PO
        Next
I figured it out...
Dim sd As Element = m_rvtDoc.GetElement(PO.ElementId)
A follow up question... When finding the end points of an edge of a solid, what is the syntax for the "EndPointReference" method?
I'm using this, but it's only returning a "nothing" value.
Dim HDAr As Reference = EELine.EndPointReference(0)
Joe.Ye
About the last question.
After you construct the Options object, you need to assign the Options.ComputerReferences = True.
Only in this way, the reference of geometry object can be retrieved.
Joe Ye
Contractor
Developer Technical Services
Autodesk Developer Network
