How to convert 3D Curve to 2D Curve
Dear Revit API experts,
I am trying to convert ramp to floor.
I have found how to do it using dynamo, now i want to do it using API.
The ramp face consists of HermiteSpline curve. (which i consider as 3D curve, am I right?)
I want to convert this curve to 2D. (XY surface)
Attached is the dynamo graph.
I want to find similar API method equivalent to Curve.Project in the dynamo.
Before Curve.Project
[0] Curve(StartPoint = Point(X = 1037.124, Y = 1761.638, Z = 0.000), EndPoint = Point(X = 1256.636, Y = 2737.248, Z = 0.000))
[1] Curve(StartPoint = Point(X = 1256.636, Y = 2737.248, Z = 0.000), EndPoint = Point(X = 2463.127, Y = -3567.063, Z = 990.600))
[2] Curve(StartPoint = Point(X = 2463.127, Y = -3567.063, Z = 990.600), EndPoint = Point(X = 1898.903, Y = -2741.441, Z = 990.600))
[3] Curve(StartPoint = Point(X = 1898.903, Y = -2741.441, Z = 990.600), EndPoint = Point(X = 1037.124, Y = 1761.638, Z = 0.000))
After:
[0] Line(StartPoint = Point(X = 1037.124, Y = 1761.638, Z = 0.000), EndPoint = Point(X = 1256.636, Y = 2737.248, Z = 0.000), Direction = Vector(X = 219.512, Y = 975.610, Z = 0.000, Length = 1000.000))
[1] NurbsCurve(Degree = 3)
[2] Line(StartPoint = Point(X = 2463.127, Y = -3567.063, Z = 0.000), EndPoint = Point(X = 1898.903, Y = -2741.441, Z = 0.000), Direction = Vector(X = -564.224, Y = 825.622, Z = 0.000, Length = 1000.000))
[3] NurbsCurve(Degree = 3)
Thanks.
Revitalizer
just an idea:
There is a Document.ConvertModelToDetailCurves method which needs a View and a ModelCurveArray as parameters.
It returns a DetailCurveArray.
So, if you create some temporary elements (View, ModelCurves, DetailCurves), you can let Revit do the projection math.
The resulting DetailCurves' GeometryCurves is what you want to get.
Revitalizer
Rudolf Honke
Software Developer
Mensch und Maschine
Hi Revitalizer,
I not yet able to draw ModelCurve of HermiteSpline or ModelNurbSpline as in this topic:
So i cant apply your idea yet. Smiley Sad
https://forums.autodesk.com/t5/revit-api-forum/how-to-draw-modelnurbspline/td-p/7500615
Anyway the good news is I already able to create floor from ramp.
The method i used: (for those who might need it)
1) draw 2D HermiteSpline curve as an arc at XY axis. (change all points to same Z value)
2) create flat floor (no slope)
3) change vertex of the floor.
Here is part of my code:
Floor floor = doc.Create.NewFloor(curvearrayFloor, true);
doc.Regenerate();
SlabShapeEditor slabshapeeditor = floor.SlabShapeEditor;
SlabShapeVertex slabshapevertex = null;
foreach (Curve curv in lstcurve) {
slabshapevertex = slabshapeeditor.DrawPoint(curv.GetEndPoint(0));
doc.Regenerate();
jeremytammik
Here are some more thoughts on various methods to create a sloped floor:
http://thebuildingcoder.typepad.com/blog/2014/03/creating-a-sloped-floor.html
Cheers,
Jeremy
Jeremy Tammik
Developer Technical Services
The Building Coder
