how to connect line with multiple family
thsa2501
thsa2501
hi everyone ,
i want to make an automatic line for family like l shape. i made this code . The line connecting the family did not meet what I expected. kindly tell me what is wrong in this code.
using Autodesk.Revit.Attributes;
using Autodesk.Revit.DB;
using Autodesk.Revit.UI;
using Autodesk.Revit.UI.Selection;
using System;
using System.Collections.Generic;
using System.Linq;
namespace PlaceDim
    [Transaction(TransactionMode.Manual)]
    public class Command : IExternalCommand
        public Result Execute(ExternalCommandData commandData, ref string message, ElementSet elements)
            UIDocument uidoc = commandData.Application.ActiveUIDocument;
            Document doc = uidoc.Document;
            try
                // Prompt the user to select multiple elements
                var selectedElements = uidoc.Selection.PickObjects(ObjectType.Element, "Select multiple families (or elements)");
                if (selectedElements.Count < 2)
                    message = "Please select at least two elements.";
                    return Result.Failed;
                // Get the points of the selected elements
                List<XYZ> points = new List<XYZ>();
                foreach (var selected in selectedElements)
                    Element element = doc.GetElement(selected);
                    LocationPoint location = element.Location as LocationPoint;
                    if (location == null)
                        message = "Selected elements must have valid location points.";
                    points.Add(location.Point);
                if (points.Count < 2)
                    message = "Failed to retrieve sufficient points from selected elements.";
                // Remove duplicate points using a HashSet
                HashSet<XYZ> uniquePoints = new HashSet<XYZ>(points);
                // Convert the HashSet back to a List (to allow sorting)
                points = uniquePoints.ToList();
                // Sort the points in ascending order first by X, then by Y
                points = points.OrderBy(p => p.X).ThenBy(p => p.Y).ToList();
                // Get the active view's plane
                View activeView = doc.ActiveView;
                Plane viewPlane = Plane.CreateByNormalAndOrigin(activeView.ViewDirection, activeView.Origin);
                // Start transaction to draw lines
                using (Transaction tx = new Transaction(doc, "Create 90 Degree L-shaped Lines"))
                    tx.Start();
                    // Create the SketchPlane inside the transaction
                    SketchPlane sketchPlane = SketchPlane.Create(doc, viewPlane);
                    if (sketchPlane == null)
                        message = "Failed to create sketch plane.";
                    // Iterate through sorted points and create L-shaped lines
                    for (int i = 0; i < points.Count - 1; i++)
                        XYZ startPoint = ProjectOntoPlane(points[i], viewPlane);
                        XYZ endPoint = ProjectOntoPlane(points[i + 1], viewPlane);
                        // If the points are in the same horizontal (X) or vertical (Y) direction, create a single line
                        if (startPoint.X == endPoint.X) // Vertical line
                            Line verticalLine = Line.CreateBound(startPoint, endPoint);
                            doc.Create.NewDetailCurve(activeView, verticalLine);
                        else if (startPoint.Y == endPoint.Y) // Horizontal line
                            Line horizontalLine = Line.CreateBound(startPoint, endPoint);
                            doc.Create.NewDetailCurve(activeView, horizontalLine);
                        else
                            // Create an L-shaped line (90-degree turn)
                            // First, create a horizontal line from the start to the same X as the endPoint
                            XYZ horizontalEnd = new XYZ(endPoint.X, startPoint.Y, startPoint.Z);
                            Line horizontalLine = Line.CreateBound(startPoint, horizontalEnd);
                            // Second, create a vertical line from horizontalEnd to the endPoint
                            Line verticalLine = Line.CreateBound(horizontalEnd, endPoint);
                    tx.Commit();
                return Result.Succeeded;
            catch (Autodesk.Revit.Exceptions.OperationCanceledException)
                return Result.Cancelled;
            catch (Exception ex)
                message = $"Error: {ex.Message} \nStackTrace: {ex.StackTrace}";
        private XYZ ProjectOntoPlane(XYZ point, Plane plane)
            // Project a point onto a given plane
            XYZ normal = plane.Normal;
            double distance = normal.DotProduct(point - plane.Origin);
            return point - distance * normal;
 the first image actual result from code
I want like this
jeremy_tammik
Please describe more precisely what you are trying to achieve. Are those three things three family instances? Would you like the connecting lines to be axis aligned? Are you working in 2D only? Do you want the connections to be as short as possible? Is the round thing marked DB always in the middle between the other two? Are there other constraints that I have not listed yet?
thsa2501
hi @jeremy_tammik
Sorry for the late reply,i need to connect multiple families with the line. The code is not coming as per the image attached.
as per the image the code wants to work. please help me.
what are you trying to say(Are you working in 2D only?).
scgq425
in you result image , the result is likely get the diff result , in you code line 63 , create a viewplane base on active view and use the view normal direction , this is the diff result reason , you can create a plane just use the (+-1,0,0) or (0,0,+-1) and run code again .
LanHui Xu 徐兰辉
Blog
LinkedIn
Revit/CAD Development | Steel Product Manager
thsa2501
hi,
thanks for the reply.it did not work.
using System;
using System.Linq;
namespace PlaceDim
            try
                // Create a custom view plane
                Plane viewPlane = Plane.CreateByNormalAndOrigin(new XYZ(0, 0, +-1), XYZ.Zero); // Use Z-axis normal for a horizontal plane
                    tx.Start();
                        if (Math.Abs(startPoint.X - endPoint.X) < 1e-6) // Vertical line
                            doc.Create.NewDetailCurve(doc.ActiveView, verticalLine);
                        else if (Math.Abs(startPoint.Y - endPoint.Y) < 1e-6) // Horizontal line
                            doc.Create.NewDetailCurve(doc.ActiveView, horizontalLine);
                        else
                    tx.Commit();
