How to check if the text of an IndependentTag is question mark?
Message 1 of 9
Anyone knows if there is a way to check if a material tag is valid a not (question mark) through API? Thanks in advance.
Replies (8)
Message 2 of 9
jeremytammik
Install RevitLookup and explore the IndependentTag properties.
One of them is TagText:
https://www.revitapidocs.com/2020/8e297dee-920d-f620-6198-0bed494e3f04.htm
Maybe the question mark is a special case and you need to check some of the other properties as well for it.
Please let us know where you find it.
Thank you.
Best regards,
Jeremy
Jeremy Tammik
Developer Technical Services
The Building Coder
Message 3 of 9
Hi Jeremy,
Thanks for your reply.
I checked that the TagText is always empty whether it is question mark or not. I also checked that the IsOrphaned property is always false. And there is no parameter can be helpful. I've no idea how to do the check now.
Message 4 of 9
jeremytammik
There are many more properties to check, e.g., TaggedElementId etc.
Are you using RevitLookup?
Jeremy Tammik
The Building Coder
Message 5 of 9
Yes, I'm using RevitLookup. TaggedElementId, GetTaggedReference also no help. I can't find a property useful for this case.
Message 6 of 9
jeremytammik
What action in the user interface cases the question mark? What can you do in the UI to make it go away? Analyse the results in RevitLookup.
Jeremy Tammik
The Building Coder
Message 7 of 9
jeremytammik
I just by chance happened to notice that this question of yours has already been raised and answered in previous threads here in the forum, e.g.:
https://forums.autodesk.com/t5/revit-api-forum/find-unhosted-tags/m-p/9049794
Jeremy Tammik
The Building Coder
Message 8 of 9
This still does not work for me. I attached a sample file. Could you please take a look when you are available? Thanks a lot.
Message 9 of 9
jeremytammik
New workarounds suggested in the thread on Material Tag created by API does not show material data:
https://forums.autodesk.com/t5/revit-api-forum/material-tag-created-by-api-does-not-show-material-da...
Can you try them out please, and let us know whether they work for you?
Thank you!
Jeremy Tammik
The Building Coder
