How to change settings in snap dialog by Revit API?
in Revit's ribbon [Manage] - [Snaps] dialog, I want to uncheck the two options: [snap to remote objects ], [snap to point clouds ]. How to do it by Revit API?
FaustoMendezcom
I can only think in 2 ways of doing it one is using PostCommand with the Windows Automation API.
public void PostableCommandExample()
UIDocument uidoc = this.ActiveUIDocument;
Document doc = uidoc.Document;
 View view = doc.ActiveView;
uidoc.Application.PostCommand(RevitCommandId.LookupCommandId("Dialog_Essentials_SnapIncrements"));
Some resources:
https://thebuildingcoder.typepad.com/blog/2013/10/programmatic-custom-add-in-external-command-launch...
 https://thebuildingcoder.typepad.com/blog/win32/
https://thebuildingcoder.typepad.com/blog/2017/12/magic-number-magic-automation-and-magic-season.htm...
and the other one using Revit Journal playback.
 Jrn.RibbonEvent "TabActivated:Manage"
 Jrn.Command "Ribbon" , "Modify snap distances or angles , ID_SETTINGS_SNAPPING"
  Jrn.CheckBox "Modal , Snaps , Dialog_Essentials_SnapIncrements" _
         , "Snap to Remote Objects, Control_Essentials_SnapDialogRemote" _
         , False
         , "Snap to Point Clouds, Control_Essentials_SnapDialogPointClouds" _
         , False
 Jrn.PushButton "Modal , Snaps , Dialog_Essentials_SnapIncrements" _
         , "OK, IDOK"
some resources :
https://thebuildingcoder.typepad.com/blog/2009/07/journal-file-replay.html
https://forums.autodesk.com/t5/revit-ideas/journal-record-and-play/idi-p/7399668
Hope it helps 🙂
Hope it helps 🙂
www.faustomendez.com
JimJia
I am sorry to say that there is currently no straightforward Revit API access to this functionality.
You may have to use Windows API to achieve your desired requirement.
Besides, You're recommended to post this request in vote forum below:
http://forums.autodesk.com/t5/revit-ideas/idb-p/302/tab/most-recent
This issue is important to me. What can I do to help?
This issue needs to be assessed by our engineering team, and prioritized against all of the other change requests that are outstanding. As a result any information that you can provide to influence this assessment will help. Please provide the following where possible:
• Impact on your application and/or your development.
• The number of users affected.
• The potential revenue impact to you.
• The potential revenue impact to Autodesk.
• Realistic timescale over which a fix would help you.
• In the case of a request for a new feature or a feature enhancement, please also provide detailed Use Cases for the workflows that this change would address.
This information is extremely important. Our engineering team have limited resources, and so must focus their efforts on the highest impact Change Requests. We do understand that this will cause you delays and affect your development planning, and we appreciate your cooperation and patience.
Jim Jia
Autodesk Forge Evangelist
https://forge.autodesk.com
Developer Technical Services
Autodesk Developer Network
Email: [email protected]
Hi
Best Regards,
