How to change settings in snap dialog by Revit API?
in Revit's ribbon [Manage] - [Snaps] dialog, I want to uncheck the two options: [snap to remote objects ], [snap to point clouds ]. How to do it by Revit API?
Thanks a lot.
jeremytammik
I am not aware of a way to change them globally for the Revit application.
You can however specify the snap settings via the ObjectSnapTypes argument when calling PickPoint:
https://apidocs.co/apps/revit/2019/7b0edd8c-ea51-0b19-7455-21d3bf3152e8.htm
Cheers,
Jeremy
Jeremy Tammik
Developer Technical Services
The Building Coder
Hi  Jeremy,
Thank you for your reply!
In ObjectSnapTypes Enumeration of PickPoint interface, there are no values about the two options: [snap to remote objects] and [snap to point clouds ]. These two options are related to application, but not related to document.
If these two options are checked, when you use PickPoint command in a medium large project, it will very slow especially at the begin. So I want to set these two options unchecked.
