how to change diameter at once
nitinjambhale
nitinjambhale
Hello All,
I m finding a solution to change diameter of pipes and fittings manually by attached screenshot.
But i m not able to get it to work with Revit API 2015.
Please help.
Thanks.
jeremytammik
Have you used RevitLookup to analyse how your manual modification affects the model, the individual elements and their properties?
Jeremy Tammik
Developer Technical Services
The Building Coder
nitinjambhale
Hi Jeremy,
Thanks for reply.
I m searching for a method to select a structure then change diameter from 2 to 1 via Revit API 2015.
But i m not able to get any method to do that...As per attached image in question this task is very easy manually.
Please suggest.
Thanks.
jeremytammik
Please always explain what research you have done yourself before asking anyone to help you.
Why should anyone help you if you do nothing at all yourself to find out?
Just searching the Internet, this is the first thing that came up:
http://adndevblog.typepad.com/aec/2012/07/changing-the-diameter-of-an-elbow-fitting-in-revit-mep-usi...
Does it help?
Best regards,
Jeremy
Jeremy Tammik
The Building Coder
nitinjambhale
Thanx again for reply jeremy.
I can set individual elements diameter but i m in search of setting at once like what revit does without needing any parameter to set.
Please suggest.
Thanks.
jeremytammik
Maybe a pipe system wide setting is affected?
Jeremy Tammik
The Building Coder
nitinjambhale
Thank you jeremy.
