How to Catch trigger in Updater for "Insulation Thickness" of Pipe.
nitinjambhale
nitinjambhale
Hello EveryOne,
I m drawing Pipe and changing its Insulation Thickness. in Revit MEP 2014 API.
 -------- Added Trigger -------
Autodesk.Revit.DB.UpdaterRegistry.AddTrigger(this.GetUpdaterId(), filter, Autodesk.Revit.DB.Element.GetChangeTypeParameter(new Autodesk.Revit.DB.ElementId(BuiltInParameter.RBS_PIPE_INSULATION_THICKNESS)));
Autodesk.Revit.DB.UpdaterRegistry.AddTrigger(this.GetUpdaterId(), filter, Autodesk.Revit.DB.Element.GetChangeTypeParameter(new Autodesk.Revit.DB.ElementId(BuiltInParameter.RBS_REFERENCE_INSULATION_THICKNESS)));
----- Catching Change ----
(data.IsChangeTriggered(id, Autodesk.Revit.DB.Element.GetChangeTypeParameter(new Autodesk.Revit.DB.ElementId(BuiltInParameter.RBS_PIPE_INSULATION_THICKNESS)))) ||
(data.IsChangeTriggered(id, Autodesk.Revit.DB.Element.GetChangeTypeParameter(new Autodesk.Revit.DB.ElementId(BuiltInParameter.RBS_REFERENCE_INSULATION_THICKNESS)))) ||
But when i change insulation thickness then above data.IsChangeTriggered(...) returning 'false' value instead of 'true'
Please advise something.
Nitin.
ollikat
Hi
unfortunatelly I don't probably have any good suggestions for this. But have to say that I haven't never used this overload of GetChangeTypeParameter() method, which takes Element id. The API documentation says: "ElementId of parameter for the ChangeType to trigger on." which is very confusing because Parameter class doesn't inherite from element. I don't trust that method at all. Do you have possibility to try the another overload?
Hopefully (but probably not) this helps.
nitinjambhale
I Cant use other overload because my filter is for Insulation Thickness only and it is a parameter.
And the other thing is Trigger for Diameter changes is working but not for Insulation Thickness.
I m still wondering may be it is API thing or so. (Without Blaming).
Thanx though.
Nitin.
