How to avoid canceling export when user use scroll wheel
Act-3D
Message 1 of 10
Act-3D
I have simple custom exporter based on IExportContext.
When during exporting I use scroll wheel then exporting is canceled in the middle of proccess (in random place).
IsCanceled() method always return false.
No exception is throw.
Question:
How to avoid canceling export when user use scroll wheel?
Replies (9)
Message 2 of 10
Act-3D
Any news about this issue?
Message 3 of 10
jeremytammik
Dear Artur,
Sorry for the late response.
Hmm. I have no news so far. I wonder how this can be communicated to the development team. I don't know how to reproduce this. Do I need any special equipment? I don't have a scroll wheel to test with. I have never heard anyone else reporting anything similar. Can you provide a reproducible case?
http://thebuildingcoder.typepad.com/blog/about-the-author.html#1b
Thank you!
Cheers,
Jeremy
Jeremy Tammik
Developer Technical Services
The Building Coder
Message 4 of 10
Act-3D
Hi Jeremy,
Thank you for answer.
Steps to reproduce:
1. Take any custom exporter
(for example: http://thebuildingcoder.typepad.com/blog/2013/07/graphics-pipeline-custom-exporter.html#5)
2. Load any Revit project
3. Go to {3D} view
4. Start export
5. During export use mouse wheel
Message 5 of 10
Act-3D
Hi Jeremy,
Did you manage to reproduce the problem?
/Artur
Message 6 of 10
jeremytammik
Dear Artur,
Thank you for your update and renewed prompting.
Yes, I have reproduced the issue.
To do so, I migrated the sample you pointed out to Revit 2017 and posted it on GitHub:
https://github.com/jeremytammik/CustomExporterCollada
When I run the command and activate the mouse scroll wheel, an exception of type ExternalApplicationException is thrown from within the call to `exporter.Export(view3D)`, saying
  Object reference not set to an instance of an object.
I remember seeing the same exception being thrown once before.
It was reported in several comments by Helen Huang on
http://thebuildingcoder.typepad.com/blog/2013/07/adn-mesh-data-custom-exporter-to-json.html
I reported it to the development team in the database issue REVIT-94525 [API CustomExporter throws ExternalApplicationException after call to Finish].
This issue has been verified by the development team and classified as Code Fix Needed, submitting a new issue REVIT-100187 [API CustomExporter throws ExternalApplicationException after call to Finish].
That issue is still open.
I added a note of your report to it.
The case faced by Helen was easy to work around: simply add an exception handler around the call to `Finish`:
  try
    exporter.Export( view );
  catch( Autodesk.Revit.Exceptions.ExternalApplicationException ex )
    Debug.Print( "ExternalApplicationException " + ex.Message );
Here is the code for that case on GitHub:
https://github.com/jeremytammik/CustomExporterAdnMeshJson
Here is the fix I applied:
https://github.com/jeremytammik/CustomExporterAdnMeshJson/blob/master/CustomExporterAdnMeshJson/Comm...
I created a new GitHub repository for the sample you pointed to:
It contains the code you point to in a solution for Revit 2017.
I added the same workaround to your code as well:
https://github.com/jeremytammik/CustomExporterCollada/commit/f734407aca033c42295e8748544d630ee51075c...
That seems to resolve the problem.
The fixed version is marked as release 2017.0.0.1:
https://github.com/jeremytammik/CustomExporterCollada/releases/tag/2017.0.0.1
I hope this helps.
Best regards,
Jeremy
Jeremy Tammik
The Building Coder
Message 7 of 10
Act-3D
Thank you Jeremy,
The another workaround I found is to disable of scroll wheel for the time of export.
Message 8 of 10
jeremytammik
How do you disable the use of the scroll wheel for the time of export, please?
Thank you!
Cheers,
Jeremy
Jeremy Tammik
The Building Coder
Message 9 of 10
Act-3D
I used EnableWindow() function on view window.
The name of view window ("AfxFrameOrView140u") I found via Spy++.
Here is class I made. Tested on Revit 2017 so far.
 class RevitWindowUtility
        [DllImport("user32.dll", SetLastError = true)]
        public static extern IntPtr FindWindowEx(IntPtr hwndParent, IntPtr hwndChildAfter, string lpszClass, string lpszWindow);
        [DllImport("user32.dll")]
        [return: MarshalAs(UnmanagedType.Bool)]
        static extern bool EnableWindow(IntPtr hWnd, bool bEnable);
        static IntPtr viewWindowHwnd = IntPtr.Zero;
        public static IntPtr FindChildWindow(IntPtr hwndParent, string lpszClass, string lpszTitle)
            return FindChildWindow(hwndParent, IntPtr.Zero, lpszClass, lpszTitle);
        public static IntPtr FindChildWindow(IntPtr hwndParent, IntPtr hwndChildAfter, string lpszClass, string lpszTitle)
            IntPtr hwnd = FindWindowEx(hwndParent, IntPtr.Zero, lpszClass, lpszTitle);
            if (hwnd == IntPtr.Zero)
                IntPtr hwndChild = FindWindowEx(hwndParent, IntPtr.Zero, null, null);
                while (hwndChild != IntPtr.Zero && hwnd == IntPtr.Zero)
                    hwnd = FindChildWindow(hwndChild, IntPtr.Zero, lpszClass, lpszTitle);
                        hwndChild = FindWindowEx(hwndParent, hwndChild, null, null);
            return hwnd;
        public static IntPtr GetRevitMainWindowHwnd()
            Process process = Process.GetCurrentProcess();
            return process.MainWindowHandle;
        public static void FindViewWindowHwnd()
            IntPtr mainWindowHwnd = GetRevitMainWindowHwnd();
            viewWindowHwnd = FindChildWindow(mainWindowHwnd, IntPtr.Zero, "AfxFrameOrView140u", null);
        public static void EnableViewWindow(bool enable)
            if (viewWindowHwnd == IntPtr.Zero)
                FindViewWindowHwnd();
            if (viewWindowHwnd != IntPtr.Zero)
                EnableWindow(viewWindowHwnd, enable);
Message 10 of 10
jeremytammik
Dear Artur,
Thank you for your super cool sample code snippet.
I hope others can find lots of interesting uses for this direct access to the view window.
Long live Spy++!
Cheers,
Jeremy
Jeremy Tammik
The Building Coder
