How to add the login name (edited by whom) into the Revit title block
madhusudhana_rao
Message 1 of 11
madhusudhana_rao
Hi All,
Can someone help me to set a variable name for adding Login Name in the revit title sheet.
Default "Filepath" parameter is not serving my requirement.
If anyone provide a small API on this, it would be greatly appreciated.
Madhu
Replies (10)
Message 2 of 11
TripleM-Dev.net
Is this Username Property what you're looking for?
- Michel
Message 3 of 11
madhusudhana_rao
Login name
Madhu
Message 4 of 11
TripleM-Dev.net
What steps do you want to perform and when?
1. Get Login Name (Username = name AutoDesk account logged into Revit) or Windows Login Name?
2. Fill it into the "Drawn By" default sheet field or a custom one (own Shared parameter in title block and sheet views)
3. During print, creation of sheet, or button ??
- Michel
Message 5 of 11
dtpeter2901
I'd love to be able to get the Revit Username field into a title block as a custom parameter, just so I can put it in the margin and know who printed the sheet.  Just like a Plotstamp in Autocad would do.
I used to be able to do this with a file name, but we're on 360 so the local file path is no longer displayed.
Message 6 of 11
joshua.lumley
This is how you get the windows login name.
string userName = System.Security.Principal.WindowsIdentity.GetCurrent().Name.Split('\\').Last();
Easy.
Message 7 of 11
RPTHOMAS108
If changing a parameter we point the finger at the last user that printed the sheet with the add-in not necessarily the last person that printed the sheet. Therefore also include suffixed date/time in same non-user modifiable parameter value (evidence for the defence).
If we really want to form a good prosecution/defence then we should encrypt the string value with a private key. It will appear to be gibberish in the printed sheet but when unencrypted will tell us the key facts above. Only we have the key so nobody can fabricate it. We then only have to decide where we store the private key, not in a .Net assembly!
Message 8 of 11
jaimeruiz9XSPN
Observer
Observer
I am looking for something similar.  When i spool in revit i have a spool sheet that says "Drawn By:" and i would like initials to be entered in automatically by who ever is spooling/logged in.  Could it read the autodesk login name and then assign that persons initials?
Message 9 of 11
namunagetahun
I am looking for something similar. File path does not work for workshare model.
Message 10 of 11
joshZ4NNG
did you ever find a solution?
I want to make a checklist schedule within our template that has all of our things that must be completed per sheet. So then once someone checks it as done, it will show who checked it off based on their autodesk Id.
Message 11 of 11
butchgarris
I'm looking to do something similar as well.  Still no solutions?
