How to add a new category to an existing project parameter
434977268
434977268
 string targetParamName = "测试";
BuiltInCategory newCategory = BuiltInCategory.OST_Ceilings;
DefinitionBindingMapIterator iter = document.ParameterBindings.ForwardIterator();
                while (iter.MoveNext())
                    Definition def = iter.Key;
                    if (def.Name == targetParamName)
                        ElementBinding binding = iter.Current as ElementBinding;
                        CategorySet categories = binding.Categories;
                        using (Transaction t = new Transaction(document, "Insert Category"))
                            t.Start();
                            categories.Insert(document.Settings.Categories.get_Item(newCategory));
                            t.Commit();
                        break;
This method does not add a new category to the specified project parameter. Although the members of binding.Categories increase every time the method is executed, there is no Test parameter in the Ceiling properties in the software.
Please tell me where the problem is, thank you
Mohamed_Arshad
@HI @434977268
You can't able to add new Category to existing one, But you can Create a New Category Set and then Re-Insert the in the Binding Map.
01. Create a New Category Set with Existing Categories.
02. Create a New Binding using New Category Set.
03. using https://www.revitapidocs.com/2021.1/7b613771-310d-6d89-4b69-475a68033f73.htm Add the Category.
Hope this Helps 🙂
Mohamed Arshad K
Software Developer (CAD & BIM)
 string targetParamName = "Test";
                BindingMap bdm = document.ParameterBindings;
                Category category = document.Settings.Categories.get_Item(newCategory);
                        categories.Insert(category);
                            t.Start();
                            CategorySet categorySet = new CategorySet();
                            foreach (Category item in categories)
                                categorySet.Insert(item);
                            InstanceBinding instanceBinding = document.Application.Create.NewInstanceBinding(categorySet);
                            bdm.ReInsert(def, instanceBinding);
                            t.Commit();
                        break;
I changed the code according to what you said, but I found that it still doesn’t work. Can you help me see where the problem is? Thank you
