How to access normalizedCurveParameter of a referencePoint, on a curve ?
any sample code will be a big help. The question looks simple, but I am not able to see the parameter “NormalizedCurveParameter” for referencePoint.
In Revit 2013 it was not accessible. Is it accessible now in Revit 2019 or 2020 ?
BardiaJahan
If I understand correctly you want to be able to retrieve the NormalizedCurveParameter for the reference points hosted on ReferenceCurves....
I did a little research using 'Revit Lookup' tool and this seems to be what you should do:
ReferencePoint refPoint;  //However you want to retrieve the point
PointElementReference pReference = refPoint.GetPointElementReference();
if (pReference is PointOnEdge)
     PointOnEdge pointOnEdge = pReference as PointOnEdge;
     double mValue = pointOnEdge.LocationOnCurve.MeasurementValue;
     PointOnCurveMeasurementType mType = pointOnEdge.LocationOnCurve.MeasurementType;
Thanks for the nice explanation.
Much appreciated!
Name “PointOnEdge” is so confusing.
I was looking for “PointOnCurve”.
