How to access Ceiling Type Parameters?
I am trying to access Ceiling Type parameters (ie: Type Mark or any project parameters).
In the code below, "param" stays null for Ceiling if value = "Type Mark".
Note: I can't use built-in values as the user type the names of the required parameters.
Parameter param = null;
            Element e = currentSet.FirstElement();   // currentSet is a FilteredElementCollector that may contain Ceiling elements
            if (e is FamilyInstance)
                FamilyInstance inst = (FamilyInstance)e;
                if (inst == null)
                    return null;
                // Get the parameter
                FamilySymbol symb = inst.Symbol;
                Family fam = symb.Family;
                param = inst.LookupParameter(value);
                if (param == null)
                    param = symb.LookupParameter(value);
            else if (e is Wall)
                Wall w = (e as Wall);
                param = w.WallType.LookupParameter(value);
            else if (e is RoofBase)
                RoofBase r = (e as RoofBase);
                param = r.RoofType.LookupParameter(value);
            else if (e is Ceiling)
                Ceiling c = (e as Ceiling);
// There is no equivalent to WallType or RoofType and default Lookup doesn't work. param = c.LookupParameter(value); // returns null } else { param = e.LookupParameter(value); }
Any help is much appreciated.
jeremytammik
