how to access API
This widget could not be displayed.
how to access API
how to access API
Is there any way of invoking com objects using revit api
i am having lot of samples using iExternalCommand IExternal Application. but i need to open revit and run this command.
is there way writing independent application which can communicate to revit 2008 (i don't want to use class libraries which execute internally from revit). I want to communicate externally.
pls clarify
I am quite sure that there is no COM support. All applications must
currently be run from inside Revit.
Sean D Burke, Assoc AIA
Technical Consultant
Autodesk Consulting - Building Solutions
visit - www.autodesk.com/consulting
Shyamkumar wrote:
> how to access API
> pls clarify
