How to Access a Wall Sweep from a wall instance from Revit 2015?
I'm trying to quantify a list of stacked walls.
If I used the filtered ElementCollector there is no problem because I select all an the wall sweeps that are on the project.
var collector = new FilteredElementCollector(this.Document, view.Id).WhereElementIsNotElementType();
But if I pick a collection of Stacked walls like this.
UIDocument.Selection.GetElementIds()
Only the Stacked walls are selected, with the property GetStackedWallMemberIds() I can access the walls, Is there a way to access the element id of the wall sweeps with a property?
When you have a wall sweep you can access the wall with the GetHostIds() Something similar but from the wall object.
Thanks.
Aaron.Lu
Dear,
Seems there is no way to directly get WallSweep from Wall, the only workaround is to filter all WallSweep and use GetHostIds() to check with wall it belongs to.
Aaron Lu
Developer Technical Services
Autodesk Developer Network
Thanks I thought it could be other way.
I'm going to test it and see if doesn't slow down.
Aaron.Lu
cool, looking forward to see the result 🙂
Aaron Lu
I come up with this solution
From the current selection I gather the Walls and Stacked Walls
UIDocument UIDocument;
UIDocument.Selection.GetElementIds().Select<ElementId, Element>(x => Document.GetElement(x)).Where(x =>
new BuiltInCategory[]
BuiltInCategory.OST_Walls,
BuiltInCategory.OST_StackedWalls
}.Contains((BuiltInCategory)x.Category.Id.IntegerValue));
Next I collect the Walls ids
IEnumerable<int> wallIds = currSel.Where(x => !(x as Wall).IsStackedWall).Select<Element, int>(x => x.Id.IntegerValue);
And Search for the walls contained on the Stacked walls
currSel.Where(x => (x as Wall).IsStackedWall).OfType<Wall>().ToList().ForEach(x => wallIds = wallIds.Union(x.GetStackedWallMemberIds().Select<ElementId, int>(y => y.IntegerValue)));
Then I select all the Wall Sweeps on the current view with the Filter Element Collector
IEnumerable<WallSweep> wallSweeps;
Document doc;
var collector = new FilteredElementCollector(doc).OfClass(WallSweep).ToElements();
IEnumerable<Element> selResult = from element in collector select element;
wallSweeps= selResult.OfType<WallSweep>();
And Finally collect the intersected elements
IEnumerable<Element> wsInSelWalls = wallSweeps.Where(x => x.GetHostIds().Select<ElementId, int>(y => y.IntegerValue).Intersect(wallIds).Count() > 0);
