How to access a Railing's slope options through API?
DEVR4074
DEVR4074
We can select a railing's slope option through Revit UI(manually):
"Edit Path"->pick a sketch line->then pick an option (By Host, Flat, or Sloped) on Revit UI.
Can I do this through Revit API? If yes, how?
I notice there is an Enumeration called "RailingSlopeOption " in Revit API documents, but cannot figure out how to use it.
Anyone can help or give some suggestions,
Thanks.
JimJia
hi,
I saw RailingSlopeOption in Revit API assembly, however I didn't find any API using it.
I'm communicating with engineering team on this, will keep you updated on any progress.
Jim Jia
Autodesk Forge Evangelist
https://forge.autodesk.com
Developer Technical Services
Autodesk Developer Network
Email: Jim.Jia@autodesk.com
JimJia
Per communication with engineering team, it's confirmed railing slope was not supported by API yet.
I am sorry to say that there is currently no API access to this functionality.
The engineering team already had filed wish issue item REVIT-74218 [As an API user, I need methods for Railing path height modification, so that I can define slope of the railing] as this issue requires exploration and possibly a modification to our software. Please make a note of this number for future reference.
You are welcome to request an update on the status of this issue or to provide us with additional information at any time quoting this wish list item number.
This issue is important to me. What can I do to help?
This issue needs to be assessed by our engineering team, and prioritized against all of the other change requests that are outstanding. As a result any information that you can provide to influence this assessment will help. Please provide the following where possible:
• Impact on your application and/or your development.
• The number of users affected.
• The potential revenue impact to you.
• The potential revenue impact to Autodesk.
• Realistic timescale over which a fix would help you.
• In the case of a request for a new feature or a feature enhancement, please also provide detailed Use Cases for the workflows that this change would address.
This information is extremely important. Our engineering team have limited resources, and so must focus their efforts on the highest impact Change Requests. We do understand that this will cause you delays and affect your development planning, and we appreciate your cooperation and patience.
Jim Jia
