How to access a an element in a loaded family
aclarke
aclarke
Hi all,
How can I enter a loaded family and access elements in this loaded family?  Specifically a filled region that is placed in a Title Block, I want to return this filled region's bounding box.
I have tried 'GetSubComponentIds()' and 'GetSubelements()' but both return '0'.
ISelectionFilter filter = new myFunctions.mySelectionFilter();
            Reference reference = uidoc.Selection.PickObject(ObjectType.Element, filter);
            FamilyInstance e = (FamilyInstance)doc.GetElement(reference);
            TD(e.GetSubelements().Count.ToString());
what I am doing is returning a count of sub elements, just to see if I can access them, here is the code I used
TD() is shortcut function for TaskDialog.Show("task", e.GetSubelements().Count.ToString());
When I select my title border with the code, the result is '0' but  this border is full of stuff.
Reading this, https://thebuildingcoder.typepad.com/blog/2010/02/nested-family-instance.html
Maybe I need to use 'GetSubComponentIds()' and 'SuperComponent' but I still get '0' when replacing 'GetSubelements' with 'GetSubComponentIds().  I am assuming that SuperComponent is the parent family, the definition is not clear.  But I still return '0' with GetSubComponentIds which I am assuming is the nested family since maybe SuperComponent is a parent family?  But neither definition is clear in the Revit API Doc.
Any guidance would be greatly appreciated.
AlanC.
jeremytammik
You have a Document instance representing your currently opened project model.
The loaded family is a completely different Document object.
You can retrieve the `document instance representing the loaded family via EditFamily:
https://www.revitapidocs.com/2020/56e636ee-5008-0ee5-9d6c-5f622dedfbcb.htm
It takes a Family argument that can be retrieved from the loaded family, or a family symbol, or a family instance.
Jeremy Tammik
Developer Technical Services
The Building Coder
aclarke
Thank you Jeremy
            Document familyDoc = doc.EditFamily(e.Symbol.Family);
            foreach (FilledRegion i in CollectedFilledRegion(familyDoc))
                TD(familyDoc.GetElement(i.GetTypeId()).Name);
public static List<FilledRegion> CollectedFilledRegion(Document doc)
            List<FilledRegion> collector = new FilteredElementCollector(doc)
                .OfClass(typeof(FilledRegion))
                .Cast<FilledRegion>()
                .ToList();
            return collector;
