Starting in December, we will archive content from the community that is 10 years and older. This FAQ provides more information.
Hello:
I am trying the get the Spot Elevation of a Floor. The values required are upper and lower. Is Possible to do with C#?
Thanks.
David
Hi David,
You could try getting the level that the floor is hosted to, and get the elevation from that level. If you are using an offset you would have to bring that into your calculations.
Good luck
/Martin
I am trying get the height between Floors from same level. I do not know what parameters used to calculate the height. As well, also to calculate height between a Floor and a Beam.
David
