How get material from split face?
Hello!
I try to get meterial from split face, with next code, but it not work:
Dim elements As FilteredElementCollector = New FilteredElementCollector(doc)
        Dim lstFaceSplitter As List(Of FaceSplitter) = elements.OfClass(GetType(FaceSplitter)).Cast(Of FaceSplitter)().Where(Function(a) a.SplitElementId = WW.Id).ToList
        Dim opt As New Options
        opt.View = CurrView
        opt.IncludeNonVisibleObjects = True
        For i = 0 To lstFaceSplitter.Count - 1
            Dim PaintMaterialIds As List(Of ElementId) = lstFaceSplitter(i).GetMaterialIds(True)
next
architect.bim
Hi!
You can get what you need with the following steps:
  1. Get wall solid;
  2. get list of all faces for that solid;
  3. check each face with GetRegions method; if it returns two of more faces - than it is splitted;
  4. get material using MaterialElementId property;
I've checked this algorithm - it works fine, I can see material of painted split region in Revit Lookup.
Maxim Stepannikov | Architect, BIM Manager, Instructor
helias.zografopoulos
Hey, I haven't figured a way to report painted Material of Split faces.
Could maybe explaine a bit more on your method? is this within Dynamo?
