how do i use BoundingBoxIntersectsFilter to find floors intersecting with stair BoundingBox
pnoZFP35
pnoZFP35
I'm trying to find the floors my stairs is going to and from
I am using BoundingBoxIntersectsFilter to find the floors that are intersecting with my stairs BoundingBox. when I then find the floors I want to take the one with the highest Z value, and save it to "Upper slab ref". And the one with the lowest Z value and save it to "Lower slab ref".
And now to the problem when I try to do this I will get to many floors or non at all
how can I make it so it will always find the right floors, in any given situation.
The middle stair will get 4 floors
The highest stair will get 2 floors but non of them is from the upper floor. and the lowest stair will find non at all.
code is shown below
ICollection<Element> AllStairs = new FilteredElementCollector(doc).OfCategory(BuiltInCategory.OST_Stairs).WhereElementIsNotElementType().ToElements();
                FilteredElementCollector collectorSlab = new FilteredElementCollector(doc).OfCategory(BuiltInCategory.OST_Floors).WhereElementIsNotElementType();
                foreach (Element el in AllStairs)
                    IDictionary<string, double> StairsSlab = new Dictionary<string, double>();
                    List<string> allSlabs = new List<string>();
                    BoundingBoxXYZ bb = el.get_BoundingBox(doc.ActiveView);
                    Outline outline = new Outline(bb.Min, bb.Max);
                    BoundingBoxIntersectsFilter bbfilter = new BoundingBoxIntersectsFilter(outline);
                    collectorSlab.WherePasses(bbfilter).ToElements();
                    if (collectorSlab != null)
                       foreach (Element e in collectorSlab)
                            BoundingBoxXYZ location = e.get_BoundingBox(doc.ActiveView);
                            double zPoint = location.Max.Z;
                            allSlabs.Add(e.Id.ToString());
                            StairsSlab.Add(e.Id.ToString(), zPoint);
                    if (StairsSlab[allSlabs[0]] > StairsSlab[allSlabs[1]])
                        tr.Start("Reload");
                        el.LookupParameter("Upper slab ref").Set(allSlabs[0].ToString());
                        el.LookupParameter("Lower slab ref").Set(allSlabs[1].ToString());
                        tr.Commit();
                    else
                        tr.Start("Reload");
                        el.LookupParameter("Upper slab ref").Set(allSlabs[1].ToString());
                        el.LookupParameter("Lower slab ref").Set(allSlabs[0].ToString());
                        tr.Commit();
jeremy_tammik
Are you just trying to determine the top and bottom floors reached by the multi-storey stairs? If so, I can imagine there is an easier way to do so than what you describe. For instance, is it not possible to determine the stairs' maximum and minimum vertical Z extents? Then you can easily eliminate all the floors in between those two values, and determine which of the two left over is the upper and lower one.
