How do I pick a ModelLine?
stefanome
stefanome
I can use the following code to pick a Face:
var pickedObject = uidoc.Selection.PickObject(ObjectType.Face, "Select a face");
var element = doc.GetElement(pickedObject);
var face = element.GetGeometryObjectFromReference(pickedObject) as Face;
 But I can't use the following code to pick a ModelLine:
var pickedObject = uidoc.Selection.PickObject(ObjectType.Element, "Select a curve");
var modelLine = element.GetGeometryObjectFromReference(pickedObject) as ModelLine;
The last line reports an error: "Cannot convert type 'Autodesk.Revit.DB.GeometryObject' to 'ModelLine' via a built-in conversion".
If I change the cast on the last line to Curve, it doesn't complain, but it doesn't work.
I checked some of the types and this is the result:
Debug.Print(element.GetType().Name);
// output: ModelLine
var geometryObject = element.GetGeometryObjectFromReference(pickedObject);
Debug.Print(geometryObject.GetType().Name);
// output: GeometryElement
var curve = geometryObject as Curve;
// curve is null
franciscopossetto
Hey,
I have tested this, and it worked on my side.
Reference pickObject = uiDoc.Selection.PickObject(ObjectType.Element);
ModelLine ml = doc.GetElement(pickObject.ElementId) as ModelLine;
Curve curve = ml.GeometryCurve;
XYZ endPoint = curve.GetEndPoint(1); // it return the end point correctly.
I hope it helps,
Kind regards.
Github:
https://github.com/franpossetto
stefanome
Thanks, for some reason I thought that I was supposed to always use GetGeometryObjectFromReference.
sameh.nabil
i have another way
1) select the element
2) delete the element
3) rollback
4) check the model lines in deleted elements
var pickedObject = uidoc.Selection.PickObject(ObjectType.Face, "Select a Floor");
var flor= element.GetGeometryObjectFromReference(pickedObject) as Floor;
ICollection<ElementId> ele_ids = new List<ElementId>();
Transaction transtemp = new Transaction(Cur_doc, "temp trans");
transtemp.Start();
ele_ids = Cur_doc.Delete(flor.Id);
transtemp.RollBack();
foreach (ElementId ele_id in ele_ids)
Element ele = Cur_doc.GetElement(ele_id);
if (ele is ModelLine)
LocationCurve curvyLoc = ele.Location as LocationCurve;
Curve curvy = curvyLoc.Curve;
Operation_function(ele, curvy);
thanks
Sameh Nabil
