How do I import Excel into a schedule in Dynamo?
dice-shunpei_chiba
dice-shunpei_chiba
I want to edit the Excel data exported from Revit in Dynamo and import it into Revit, but I can't do it well. I'm a beginner, so I've been trying it while looking at various things, but I don't know the solution, so if you are familiar with it, please help.
(dynamoでrevitから書き出したエクセルデータを編集してrevitに読み込みたいのですが、上手くできません。初心者なので色々見ながら試していましたが解決法が分からないので詳しい方いましたらご助力願います。)
scgq425
@dice-shunpei_chiba :
You code is ok , if the function cant run or result error , u need to check u elments result . i copy u function in my dynamo , is ok . so check the result or give more information of this problem.
LanHui Xu 徐兰辉
Blog
LinkedIn
Revit/CAD Development | Steel Product Manager
dice-shunpei_chiba
Thanks for the reply. If you check closely, the category to be input to Element.SetParameterByName is a summary table, and when I changed this to mechanical equipment, it worked.
scgq425
In u Picture , the paramater name is 'LIST' , May be this paramater is unvaild
LanHui Xu 徐兰辉
Blog
LinkedIn
dice-shunpei_chiba
The parameter I wanted to get was equipmentname. When I changed it to this and executed it, I was able to change the Excel value normally. Also, if you have any questions, please help us.
scgq425
im happy to help ur .
but , i cant understand u idea , u want to get equipment name or change excel contains import and export ?
u can post a sample project or some picture .
LanHui Xu 徐兰辉
Blog
LinkedIn
scgq425
In This , i make a function to input value to excel and export value to excel , ur can run this and tell me which error or run success .
LanHui Xu 徐兰辉
Blog
LinkedIn
