How do I a selected legendcomponent in the open EditFamily ?
a180401ta
a180401ta
Hi All,
I tried the following articles but I didn't get results.
https://thebuildingcoder.typepad.com/blog/2014/09/modifying-saving-and-reloading-families.html
https://forum.dynamobim.com/t/setting-the-builtin-parameter-accessible-thru-the-family-editor/10554/...
https://forums.autodesk.com/t5/revit-api-forum/how-to-dismiss-popups-when-going-into-quot-editfamily...
Code segment:
family = UnwrapElement(IN[0])
en = family[0]
famdoc = doc.EditFamily(en.Family)
What is the problem?
How do we fix this?
Any assistance is much appreciated.
FAIR59
The ElementId of the ElementType / FamilySymbol of the legendcomponent is stored in the BuiltInParameter..LEGEND_COMPONENT.
From the FamilySymbol you find the Family to Edit. In c# code:
// Document document;
// Element legendelement;
Parameter p = legendelement.get_Parameter(BuiltInParameter.LEGEND_COMPONENT);
if (p==null) return;
FamilySymbol symb = document.GetElement(p.AsElementId()) as FamilySymbol;
if (symb==null) return;
Family fam = symb.Family;
if(fam.IsEditable)
     Document d = document.EditFamily(fam);
a180401ta
Thank you for your reply.
But there is still no way to finish opening the "Edit Family" editor.
Current operation process Video:
https://youtu.be/-nfDuS8Nl2w
[Autodesk.Revit.Attributes.Transaction(Autodesk.Revit.Attributes.TransactionMode.Manual)]
[Autodesk.Revit.Attributes.Regeneration(Autodesk.Revit.Attributes.RegenerationOption.Manual)]
public class Cs18_TestEditFamily : IExternalCommand
    public Result Execute(ExternalCommandData commandData, ref string message, ElementSet elements)
    UIApplication uiapp = commandData.Application;
    UIDocument uidoc = uiapp.ActiveUIDocument;
    Document doc = uidoc.Document;
    Autodesk.Revit.DB.View view = uidoc.ActiveView;
    Autodesk.Revit.ApplicationServices.Application app = uiapp.Application;
    Reference r;
    r = uidoc.Selection.PickObject(ObjectType.Element, "Selection Element");
    var elem = doc.GetElement(r.ElementId);
    Parameter p = elem.get_Parameter(BuiltInParameter.LEGEND_COMPONENT);
    if (p == null) { MessageBox.Show("Selection null"); }
    FamilySymbol symb = doc.GetElement(p.AsElementId()) as FamilySymbol;
    if (symb == null) { MessageBox.Show("Selection null"); }
    if (fam.IsEditable)
        MessageBox.Show("True");
        Document d = doc.EditFamily(fam);
    return Result.Succeeded;
My English is pretty limited, please don't mind.
How do we fix this?
FAIR59
With the call to Document.EditFamily(), the family opens in the background.
To open the family like  pressing the [Edit Family] button, add this code.
//Document d = document.EditFamily(fam);
IEnumerable<ViewPlan> plans = new FilteredElementCollector(d)
					.OfClass(typeof(ViewPlan))
					.Cast<ViewPlan>()
					.Where( vp=>!vp.IsTemplate);
ViewPlan v = plans.FirstOrDefault();
if (v==null) return;
UIDocument uidoc = new UIDocument(d);
IEnumerable<ElementId> ids = new FilteredElementCollector(d,v.Id)
				.ToElementIds();
uidoc.Application.DialogBoxShowing+= ThisApplication_DialogBoxShowing; uidoc.ShowElements(ids.ToList()); uidoc.Application.DialogBoxShowing-= ThisApplication_DialogBoxShowing;
internal void ThisApplication_DialogBoxShowing(object sender, DialogBoxShowingEventArgs e)
	e.OverrideResult((int) TaskDialogResult.Ok);
a180401ta
Thanks FAIR59.
But, not yet completed.
keep it up.
