How convert simple macro to Revit API
How converting simple macro to Revit API to create List Of Drawings:
 * Created by SharpDevelop.
 * User: MOHAMED.moussa
 * Date: 4/3/2017
 * Time: 3:25 PM
 * To change this template use Tools | Options | Coding | Edit Standard Headers.
using System;
using Autodesk.Revit.UI;
using Autodesk.Revit.DB;
using Autodesk.Revit.UI.Selection;
using System.Collections.Generic;
using System.Linq;
using System.Text;
using Autodesk.Revit.ApplicationServices;
namespace LODCREATION
    [Autodesk.Revit.Attributes.Transaction(Autodesk.Revit.Attributes.TransactionMode.Manual)]
    [Autodesk.Revit.DB.Macros.AddInId("137BBBD9-148E-4401-913F-168FDEA677C6")]
	public partial class ThisDocument
		private void Module_Startup(object sender, EventArgs e){ }
		private void Module_Shutdown(object sender, EventArgs e){ }
		public void LODCREATION()    {
			 UIApplication uiApp = this.Application;
             Application app = uiApp.Application;
             UIDocument uiDoc = uiApp.ActiveUIDocument;
             Document Doc = uiDoc.Document;
             StringBuilder sb = new StringBuilder();
             ElementCategoryFilter sheetcf = new ElementCategoryFilter(BuiltInCategory.OST_Sheets);
             FilteredElementCollector sheetCollector = new FilteredElementCollector(Doc);
             IList<Element> sheetlist = sheetCollector.WherePasses(sheetcf).WhereElementIsNotElementType().ToElements();
             foreach(Element sheet in sheetlist) {
                 FilteredElementCollector panelCollector = new FilteredElementCollector(Doc, sheet.Id);
                 IList<Element> panellist = panelCollector.WherePasses(panelcf).WhereElementIsNotElementType().ToElements();
                     sb.AppendLine(sheet.get_Parameter(BuiltInParameter.SHEET_NUMBER).AsString()
                                  + " \t"+sheet.get_Parameter(BuiltInParameter.SHEET_NAME).AsString());
			Autodesk.Revit.DB.XYZ baseVec = Document.Application.Create.NewXYZ(0.0, 0.0, 1.0);
			Autodesk.Revit.DB.XYZ upVec = Document.Application.Create.NewXYZ(0.0, 0.0, 1.0);
			Autodesk.Revit.DB.XYZ origin = Document.Application.Create.NewXYZ(0.0, 0.0, 0.0);
			Autodesk.Revit.DB.XYZ origin1 = Document.Application.Create.NewXYZ(0.0, 3.0, 0.0);
			Autodesk.Revit.DB.TextAlignFlags align = Autodesk.Revit.DB.TextAlignFlags.TEF_ALIGN_LEFT | Autodesk.Revit.DB.TextAlignFlags.TEF_ALIGN_TOP;
            string strText = sb.ToString(); //-----------
			double lineWidth = 4.0 / 12.0;
			Autodesk.Revit.DB.Transaction t = new Autodesk.Revit.DB.Transaction(Document, "NewTextNote");
			t.Start();
			Autodesk.Revit.DB.View pView = Document.ActiveView;
			Document.Create.NewTextNote(pView,origin1, baseVec, upVec, lineWidth, align, strText);
			t.Commit();
		#region Revit Macros generated code
		private void InternalStartup()
			this.Startup += new System.EventHandler(Module_Startup);
			this.Shutdown += new System.EventHandler(Module_Shutdown);
		#endregion
Excuse while it's the first Revit Macro.
Replies (7)
IbrahimNaeem
Follow along with the steps mentioned in the following URL
http://usa.autodesk.com/adsk/servlet/index?siteID=123112&id=16849339
Thanks, Ibrahim Naeem
Thanks Ibrahim for reply,I know that steps but the code gave errors when moved to CS file at visual studio.
IbrahimNaeem
	public class ThisDocument : IExternalCommand  //subscribe to //the interface
                 public Result Execute(ExternalCommandData commandData, ref string message, ElementSet elements)
  \\Write your Code here.
  \\ get everything from the document and application from CommandData \\parameter
Document doc = commandData.Application.ActiveUIDocument.Document;
 Application app = doc.Application;
\\Continue to write and adjust your code
return Result.Succeeded;
Use the Manifest file as described in the link given before.
After finishing with build succeeded , you'll find your button under external tools in the addins tab
Thanks for solving,
The final working code is:
using System;
using System.Linq;
using Autodesk.Revit.DB.Architecture;
using Autodesk.Revit.Attributes;
using System.Text;
[TransactionAttribute(TransactionMode.Manual)]
[RegenerationAttribute(RegenerationOption.Manual)]
public class Lab1PlaceGroup : IExternalCommand
      ref string message,
        //Get application and document objects
        UIApplication uiApp = commandData.Application;
        Document doc = uiApp.ActiveUIDocument.Document;
        FilteredElementCollector sheetCollector = new FilteredElementCollector(doc);
        foreach (Element sheet in sheetlist)
            FilteredElementCollector panelCollector = new FilteredElementCollector(doc, sheet.Id);
                         + " \t" + sheet.get_Parameter(BuiltInParameter.SHEET_NAME).AsString());
        XYZ baseVec = new XYZ(0.0, 0.0, 1.0);
        XYZ upVec = new XYZ(0.0, 0.0, 1.0);
        XYZ origin = new XYZ(0.0, 0.0, 0.0);
        XYZ origin1 = new XYZ(0.0, 3.0, 0.0);
        Autodesk.Revit.DB.Transaction t = new Autodesk.Revit.DB.Transaction(doc, "NewTextNote");
        t.Start();
        Autodesk.Revit.DB.View pView = doc.ActiveView;
        doc.Create.NewTextNote(pView, origin1, baseVec, upVec, lineWidth, align, strText);
        t.Commit();
Finally if you have optimization to show more sheet data(in addition to name and number like system..etc) in the list of drawings Also to fit the LOD to the sheet I will be appreciate that.
Many thanks.
IbrahimNaeem
Glad that the problem has been solved. Now I'm asking why do you use a text to show sheet data, you have already a schedule where you can define parameters and everything?
Where is that schedule?
Founded
