How can I use IExportContext to export the LOD of a element?
Message 1 of 1
IExportContext is much easier to export mesh/geometry from revit, but it seems there is no way to set the LOD level or get all LOD level of a element?
If I don't use IExportContext, seems there is no easy way to access the UV information. so in order to export meshes, the only way is to use IExportContext right?
Then how can I export all the LOD level if a element have when using IExportContext to export meshes?
Replies (0)
