How can I get the connected devices ID at the end of the wire?
nur91m
nur91m
I'm trying to get the devices ID at the end of the wire. I looked for wire class methods and parameters, but couldn't find anything. If someone knows please help me to solve this problem.
Aaron.Lu
The Wire has property Wire.ConnectorManager, you can get Connectors from it, and check the connector's AllRefs property to get the connected connectors, then from those connectors, you can get the connected elements.
this can be applied to all MEP related system, including Piping and ducting.
foreach (Connector connector in wire.ConnectorManager.Connectors)
if (connector.IsConnected)
foreach (Connector con in connector.AllRefs)
var connectedElement = con.Owner; //here it is
Aaron Lu
Developer Technical Services
Autodesk Developer Network
