How can I find a FamilySymbol through a FamilyInstance Parameter ?
Bruno_Neves_Pires_Silva
            I want to insert a FamilyInstance that contains a parameter named 'XPTO.' How do I find the right FamilySymbol since the parameter is in the FamilyInstance, not in the FamilySymbol? The name of the FamilySymbol is not known.
Thank you in advance
jeremy_tammik
Filtered element collector to retrieve all family instances, check each one for the required parameter; when the correct instance is found, call its FamilyInstance.Symbol property:
But I don't have any familyInstance inserted yet.
I want to find a FamilySymbol that when is inserted, the result FamilyInstance will have the parameter "XPTO".
