How Can I easy convert(support) my Addin DLL. from 2012 to 2014?
Hello.
i (infact... my company boss) make a Addin for REVIT 2012.
but, our addin raise error in REVIT 2014.
like
'System.MissingMethodException ( at Revit : can not find method)'
'Autodesk.Revit.DB.Element
Autodesk.Revit.DB.Document.get_Element(System.String)'
  Location : [myAddin].S_myRevitThread.MakeData(UIDocument AUIDoc, String AFlag, String AParam)
..... etc....
how can i find
blocked / changed code ( and what is new code for this changes)?
The API dropped in 2014 should be maked as obsolete in 2013.
You can look at the 2013 API documentation for alternatives.
For example,
Document.Element property (String) is annotated with
[ObsoleteAttribute("This method has been obsoleted. Use GetElement() instead.")]
Recompile your souce code with 2014 API should give you errors for missing method and warnings for obsoleted method.
