How can get the Floor elevation and Beam elevaton?.
Hello everyone:
1. How can get the Floor elevation and Beam elevation?. I need the Double value.
2. How can get the nether elevation the same element (Floor)?
Thanks.
David
jeremytammik
Dear Frank,
I am happy to see that you are using RevitLookup to explore the database.
It enables you to answer these question yourself, if you look more closely.
In this case, I would suggest something like this:
  Floor floor = ... ;
  Level level = doc.GetElement( floor.LevelId ) as Level;
  double elevation = level.Elevation;
Good luck!
Cheers,
Jeremy
Jeremy Tammik
Developer Technical Services
The Building Coder
Dear Jeremy:
Revit RevitLookup is a excellent tools and newly I am learning to use it.
About my problem: First I need get Beam Elevation but not works the code. Which I am doing bad?
The message:
The code:
if (category == "Structural Framing")
                    FilteredElementCollector collector = new FilteredElementCollector(m_revit.ActiveUIDocument.Document).OfClass(typeof(FamilyInstance));
                    int i = 0;
                    foreach (FamilyInstance fi in collector)
                        if (fi.StructuralType == StructuralType.Beam)
                            //Get parameter "H" Height
                            Parameter family = fi.LookupParameter("Family");
                            if (family.AsValueString() == "Regular Rectangular Concreto")
                                //Get parameter "Tipo de Altura"
                                Parameter tipoAltura = fi.get_Parameter(new Guid("e9432adc-dbf1-48f2-b34e-20be6ab708e5"));
                                //Get parameter "Encofrado"
                                Parameter encofrado = fi.get_Parameter(new Guid("3bfb766d-e81e-4e39-98d0-046a606a17b3"));
                                //Get parameter "z Offset value"
                                Parameter zOffsetValue = fi.LookupParameter("z Offset Value");
                                //Get parameter "Peralte - H"
                                //Parameter H = fi.LookupParameter("H");
                                ElementId elemTypeId = fi.GetTypeId();
                                ElementType myType = (ElementType)m_revit.ActiveUIDocument.Document.GetElement(elemTypeId);
                                Parameter H = myType.LookupParameter("H");
                                //Get level the Beam ;
                                Level level = m_revit.ActiveUIDocument.Document.GetElement(fi.LevelId) as Level;
                                string elevationName = level.Name;
                                TaskDialog.Show("GYM-BIM", "Collector = " + fi.Name
                                                + "\nContador = " + i
                                                + "\nId =" + fi.Id
                                                + "\nzOffsetValue =" + ParameterToString(zOffsetValue)
                                                + "\nH =" + ParameterToString(H)
                                                + "\nLevel Value =" + elevation
                                                + "\nLevel Name=" + elevationName
                                i++;
                        if (i == 30)
                            break;
Thanks for your help.
