Hilight object by elementid
HI,
I am writing a code for hilight all rebars with rebar number that  coincide with a texbox in  a form.
I am thinking to create a ilist and add the rebar with this line:
Dim ListSel As IList(Of ElementId) = Nothing
when i find a rebar with the correct number i add it to the list:
ListSel.Add(id_Pos)
where id_pos is a variable as elementid
But I receive an exception on this point.
When I crete  the ilist, can I hilight all the objects in the list?
RPTHOMAS108
You can't add items to a null reference.
IList is an interface (can only be obtained, not created) use instead List(Of ElementID) i.e. Dim ListSel As New List(Of ElementId)
Not sure what is meant by highlight but to select elements in the model (highlighting them) you can use:
uidoc.Selection.SetElementIds(ListSel)
There is an example of this in the RevitAPI.chm file under 'Selection Class'
thank so much!!!
it was just what I was looking for!!
