Highlight a point in view
bimspaceengenharia
bimspaceengenharia
Hello Everyone!
I am trying to highlight  a point in Revit`s view, and I saw that it is possible to do it in Dynamo.  When a I create a point in dynamo, I also get a preview of that point in my revit document. Is there a way to highlight this point through Revit`s API?
Here`s the link of a similar question that I found at Dynamo`s forum, maybe it can help you understand:
https://forum.dynamobim.com/t/dynamo-point-preview-visiblity/22785
naveen.kumar.t
Autodesk Support
Autodesk Support
bimspaceengenharia
I would like to do similar to these pipe gifs without using any transactions. I looked at this first link and I'm still using spheres.
I'll show you what i have until now, in the video you can see that I'm selecting the connector desired by the user and it creates a sphere that was  created with DirectShape, but that way I have several transactions that I don't want to have and still need to delete the created directshape.
## How im doing ##
https://imgur.com/a/TbYgZFG
naveen.kumar.t
Autodesk Support
Autodesk Support
Hi @bimspaceengenharia ,
I am not able to understand your problem clearly. The GIF you attached is not clear.
It looks like you were able to create a direct shape at the point you are selecting.
Are you trying to do this without any transactions?
Could you please explain your problem in detail(With screenshots)?
I am not an expert in Dynamo. If Dynamo is doing it, it's possible. It might be creating some temporary geometry or even a temporary Revit object representing the point. But looking at the code for those nodes would probably help identify the technique used.
Naveen Kumar T
Developer Technical Services
Autodesk Developer Network
