Hide Label in Revit C#
        I trying to hide the tag (Material and Finish) , which having <By Category> value in Revit Project. I'm not able to do it by manually. If I changed the label its reflecting in every families.Beacuse single label has been used for every families.Please provide me the solution.
Vinoth
Revitalizer
Hi Vinoth,
you say:
"I'm not able to do it by manually."
To answer your question independent on the thing you want to perform:
What can be done via API is just a subset of the functions the user can access via GUI.
There is nearly nothing that can be done by API exclusively, perhaps setting invisible parameters or so.
(Okay, you can write X-data to Elements, write triggers and so on.)
Thus, if you cannot do it manually, you also cannot do it using API.
Revitalizer
Rudolf Honke
Software Developer
Mensch und Maschine
