Help with setting rebar layout rule
03:52 AM
Revit 2018 API and versions prior had the following methods which were removed with the release of the 2019 API:
- Autodesk.Revit.DB.Structure.Rebar.SetLayoutAsFixedNumber()
- Autodesk.Revit.DB.Structure.Rebar.SetLayoutAsMaximumSpacing()
- Autodesk.Revit.DB.Structure.Rebar.SetLayoutAsMinimumClearSpacing()
- Autodesk.Revit.DB.Structure.Rebar.SetLayoutAsNumberWithSpacing()
- Autodesk.Revit.DB.Structure.Rebar.SetLayoutAsSingle()
I have been trying to change the layout rule setting for a set of rebars without any success. Is there any replacement for the above mentioned methods that I do not know of? Could someone explain how one sets the layout rule for a given rebar element with Revit 2019 API?
I will be grateful for any assistance offered.
