Help with Retrieving "Center" Reference for Structural Columns in Revit API
ahmadkhalaf7892
ahmadkhalaf7892
Hello everyone,
I am trying to annotate structural columns by creating aligned dimensions between their centers. However, I’m facing an issue when attempting to retrieve the reference for the "Center (Left/Right)" using the GetReferenceByName method. It doesn't always work as expected for structural columns.
Here's a simplified explanation of my approach:
  1. I am working with a list of structural columns (FamilyInstance objects).
  2. For each column, I try to get its "Center (Left/Right)" reference like this:
    csharp Example :
    Reference centerReference = pile.GetReferenceByName("Center (Left/Right)");
  3. Unfortunately, this sometimes returns with different results than what I want, which stops me from continuing with my dimension creation.
My Question:
Is there a reliable way to get the center reference ( the center point) of a structural column in the Revit API? If not through GetReferenceByName, is there another method or approach I can use to determine the geometric center or reference of the column as a reference for annotation ?
Any guidance or alternative suggestions would be greatly appreciated!
Thank you in advance for your help!
ahmadkhalaf7892
https://thebuildingcoder.typepad.com/blog/2014/11/picking-pairs-and-dimensioning-family-instance-ori...
Found the solution here in this topic discussed before by Jeremy Tammik
static Reference GetFamilyInstancePointReference(
FamilyInstance fi )
return fi.get_Geometry( _opt )
.OfType<Point>()
.Select<Point, Reference>( x => x.Reference )
.FirstOrDefault();
Just make sure to change the options also.
