Help me to get a CSV file from LookUp Table.
holyhuman1
holyhuman1
Hi, all!
I've been struggling get a CSV file from LookUp Table in specific Family. I thought it is easy but there are always "file access exception" when using FamilySizeTableManager.ExportSizeTable().
here's my code.
public Result Execute(ExternalCommandData commandData, ref string message, ElementSet elements)
FamilySymbol fs = (elem as FamilyInstance).Symbol;
FamilySizeTableManager fstm = FamilySizeTableManager.GetFamilySizeTableManager(doc, fs.Family.Id);
using (Transaction trans = new Transaction(doc))
trans.Start("Start");
if (fstm.ExportSizeTable("Really exist name in Lookuptable", AssemblyDirectory))
// success
else
// fail.
trans.Commit();
Are there anyone who already encountered and solved this issue?
thank you!
jeremy_tammik
The ExportSizeTable method takes two arguments: the table name to export and a file path to export it to:
https://www.revitapidocs.com/2021.1/40539d6c-8288-94cb-0052-2e8203d15e43.htm
The file path must be a valid text file path and you must have write access to that.
You file path variable name is `AssemblyDirectory`. That sounds like a directory name to me, not a file path. Maybe that is your problem. Furthermore, you may not have write access to that directory. Try a different file path.
holyhuman1
Thank you jeremy! i finally found the problem. the code should be like this.
// if (fstm.ExportSizeTable("Really exist name in Lookuptable", AssemblyDirectory))
if (fstm.ExportSizeTable("Really exist name in Lookuptable", AssemblyDirectory + "Really exist name in Lookuptable"+".csv" ))
// success
else
// fail.
trans.Commit();
Thank you again!!
