HELP: How get the "StringValue" of shared parameter?
Hello everyone:
How can getting of a Element the value the properties and shared parameters efficiently?.
See image:
I am using the following code, but not works because the result is "none".
Parameter gymCategoria = fi.LookupParameter("Categoria GyM");
TaskDialog.Show("GYM-BIM", "Collector = " + ParameterToString(gymCategoria));
/// <summary>
/// Helper function: return a string form of a given parameter.
/// </summary>
        public static string ParameterToString(Parameter param)
            string val = "none";
            if (param == null)
                return val;
            // To get to the parameter value, we need to pause it depending on its storage type
            switch (param.StorageType)
                case StorageType.Double:
                    double dVal = param.AsDouble() * 0.3048;
                    val = dVal.ToString();
                    break;
                case StorageType.Integer:
                    int iVal = param.AsInteger();
                    val = iVal.ToString();
                    break;
                case StorageType.String:
                    string sVal = param.AsString();
                    val = sVal;
                    break;
                case StorageType.ElementId:
                    ElementId idVal = param.AsElementId();
                    val = idVal.IntegerValue.ToString();
                    break;
                case StorageType.None:
                    break;
            return val;
Thanks.
It looks like you are dealing with a type parameter in this situation.
As such, you need to retrieve the parameter from the FamilySymbol, and not from the FamilyInstance.
If you change
to
Parameter gymCategoria = fi.Symbol.LookupParameter("Categoria GyM");
then you should be able to correctly read its value.
I executed the change but does not work :(.
Keeps coming "none"
Heré the code complete:
public void GenerateFormworkToElements(string category)
            SubTransaction createFormwork = new SubTransaction(m_revit.ActiveUIDocument.Document);
            try
                createFormwork.Start();
                FilteredElementCollector collector = new FilteredElementCollector(m_revit.ActiveUIDocument.Document).OfClass(typeof(FamilyInstance));
                if (category == "Structural Columns")
                    int i = 0;
                    foreach (FamilyInstance fi in collector)
                        if (fi.StructuralType == StructuralType.Column)
                            //Get parameter "Tipo de Altura"
                            Parameter tipoAltura = fi.LookupParameter("Tipo de Altura");
                            //Get parameter "H" Height
                            Parameter  height = fi.LookupParameter("H");
                            //Get parameter "Encofrado"
                            Parameter encofrado = fi.LookupParameter("Encofrado");
                            //Get parameter "GyM Categoría"
                            TaskDialog.Show("GYM-BIM", "Collector = " + fi.Name
                                            + "\nContador = " + i
                                            + "\nId =" + fi.Id
                                + "\nCategory = " + ParameterToString(gymCategoria)
                                + "\nHeight = " + ParameterToString(height)
                                + "\nTipo Altura = " + ParameterToString(tipoAltura)
                                + "\nEncofrado = " + ParameterToString(encofrado)
                            if (i == 5)
                                break;
                            i++;
                    TaskDialog.Show("GYM-BIM", "Collector Total = " + i);
                createFormwork.Commit();
            catch (Exception ex)
                TaskDialog.Show("GenerateFormworkToElements", "Error = " + ex.Message);
                createFormwork.RollBack();
        /// <summary>
        /// </summary>
            if (param == null)
                return val;
                    break;
                    break;
                    val = sVal;
                    break;
                    break;
                    break;
            return val;
Thanks very much for your help.
David
Can you find the GUID of the parameter from your shared parameters file, and then attempt to lookup the parameter using
Parameter gymCategoria = fi.get_Parameter(new Guid("GUIDVALUEFROMSHAREDPARAMFILE"));
For some reason, the parameter isn't being found when you are looking it up by name.  I don't see any other issues with the code.
I don't believe that it's possible for a shared parameter to have a StorageType of None.
However, to be sure that the error is happening when trying to lookup the parameter, can you change
    break;
to
val = "StorageTypeNone"; break;
