Revit API Forum
Welcome to Autodeskā€™s Revit API Forums. Share your knowledge, ask questions, and explore popular Revit API topics.
Showing results forĀ
Did you mean:Ā
[help] Handle warning before commit
9 REPLIES 9
Message 1 of 10
2270 Views, 9 Replies
Follow this topic :
https://thebuildingcoder.typepad.com/blog/2014/05/on-handling-warnings-and-failures.html
We just can dismiss warning when we committed transaction,we want  some of warnings to process with commit , and some of warning to cancel.  But to save time ,we dont allow revit regenerate document many times  so we commit transaction of the end of process.
Can I dismiss warning before I commit transaction,
Tags (1)
9 REPLIES 9
Message 2 of 10
MarryTookMyCoffe
not in the way you thing, but I thing you can do a subtransaction in transaction to catch warring of part that are important for you to progress further in  your app.
https://knowledge.autodesk.com/search-result/caas/CloudHelp/cloudhelp/2016/ENU/Revit-API/files/GUID-...
http://www.revitapidocs.com/2015/801e5f17-cab0-044d-835c-a39592374f89.htm
do not worry it only gonna take Autodesk 5 years to fix bug
Message 3 of 10
in reply to: MarryTookMyCoffe
Thank mary so much ,
But i have some trouble , try catch my code but i didnt get any message from catch but my sub transaction return rollback. Please help me, how do we know why subtransaction rollback
Message 4 of 10
MarryTookMyCoffe
I never tested it in full, but maybe when subtranasction end or roll back, the main transaction get warring or errors to a failuresPreprocessor class:
https://help.autodesk.com/view/RVT/2015/ENU/?guid=GUID-52A45CC1-3BB4-48B4-BFC7-F6F8666C2AA4
unfortunately revit api was made for small macros.
It is possible that you will need to make many transaction, many times there is just no easy way out in Revit API.
what exactly you try to do? some times it is easier to catch invalid parameters before transaction.
Message 5 of 10
Thank marry so much,
I found reason why because my model has too many warning so they always return rollback, I solve all warning and they return committed , everything now is fine. Thank you for your help. Have a good day šŸ™‚
Message 6 of 10
One more thing, to improve performance of code I use this syntax:
Snippet
[Regeneration(RegenerationOption.Manual)]
but the document still regenerates when I commits transaction. Do you have any solution to limit number of times the document regenerates?
Message 7 of 10
MarryTookMyCoffe
commit always will regenerate document there is nothing you can do about it.
the
is thing from past(I thing before 2013 or something like that) when we could make it automatic. There is not much you can do about optimization, my suggest is to use:
if you create many object
document.Create.NewFamilyInstances2 - I thing it work a little faster than making all element with document.Create.NewFamilyInstances.
Message 8 of 10
One more question, I dont know why I cannot get failure handle  when transaction return rollback , i can not get list of element  cause error. Do you have any idea?
Message 9 of 10
MarryTookMyCoffe
I thing that answer is here:
http://www.revitapidocs.com/2016/d99de9ee-168e-a114-1255-0cea9f317efb.htm
you can add handling option to a roll back
Message 10 of 10
I tried, but it doesn't work šŸ˜ž
