Has anyone implemented revision clouds around selected elements on the sheet?
baleti3266
baleti3266
I'm trying to write a command that draws revision clouds around selected elements. It works fine when revision clouds are drawn in the view, but when I'm trying to draw them on the sheet matching their corresponding locations of selected elements in view they don't land in correct locations. They get shifted in either direction by small amounts. Does anyone know why?
using Autodesk.Revit.Attributes;
using Autodesk.Revit.DB;
using Autodesk.Revit.UI;
using System;
using System.Collections.Generic;
using System.Linq;
[Transaction(TransactionMode.Manual)]
public class CloudsToSheetParametric : IExternalCommand
    public Result Execute(
        ExternalCommandData cd,
        ref string message,
        ElementSet elements)
        UIDocument uiDoc = cd.Application.ActiveUIDocument;
        Document   doc   = uiDoc.Document;
        View       view  = doc.ActiveView;
        ICollection<ElementId> selIds = uiDoc.Selection.GetElementIds();
        if (!selIds.Any())
            message = "Select one or more elements first.";
            return Result.Failed;
        // ─── locate the viewport that shows the active view ───
        ViewSheet sheet = null;
        Viewport  vp    = null;
        foreach (ViewSheet sh in new FilteredElementCollector(doc)
                                 .OfClass(typeof(ViewSheet)))
            foreach (ElementId vpid in sh.GetAllViewports())
                vp = doc.GetElement(vpid) as Viewport;
                if (vp != null && vp.ViewId == view.Id)
                    sheet = sh;
                    break;
            if (sheet != null) break;
        if (sheet == null)
            message = "Active view is not placed on a sheet.";
        // ─── build parametric mapper ───
        ParamMapper map;
        try
            map = new ParamMapper(view, vp);
        catch (InvalidOperationException ex)
            message = ex.Message;
        // ─── choose (or create) a revision ───
        Revision rev = GetLatestVisibleRevision(doc);
        if (rev == null)
            using (Transaction t = new Transaction(doc, "Create Revision"))
                t.Start();
                rev = Revision.Create(doc);
                t.Commit();
        const double OFFSET = 0.2;         // ft – halo
        // ─── build sheet-space rectangles ───
        var curves = new List<Curve>();
        foreach (ElementId id in selIds)
            Element el = doc.GetElement(id);
            BoundingBoxXYZ bb = el.get_BoundingBox(view);
            if (bb == null) continue;
            // model-space bbox (expanded)
            XYZ p1 = bb.Transform.OfPoint(bb.Min);
            XYZ p2 = bb.Transform.OfPoint(bb.Max);
            XYZ min = new XYZ(
                Math.Min(p1.X, p2.X) - OFFSET,
                Math.Min(p1.Y, p2.Y) - OFFSET, 0);
            XYZ max = new XYZ(
                Math.Max(p1.X, p2.X) + OFFSET,
                Math.Max(p1.Y, p2.Y) + OFFSET, 0);
            // sheet points via param mapper
            XYZ bl = map.ToSheet(min);                       // bottom-left
            XYZ tl = map.ToSheet(new XYZ(min.X, max.Y, 0));  // top-left
            XYZ tr = map.ToSheet(max);                       // top-right
            XYZ br = map.ToSheet(new XYZ(max.X, min.Y, 0));  // bottom-right
            curves.Add(Line.CreateBound(bl, tl));
            curves.Add(Line.CreateBound(tl, tr));
            curves.Add(Line.CreateBound(tr, br));
            curves.Add(Line.CreateBound(br, bl));
        if (!curves.Any())
            message = "No bounding boxes found.";
        // ─── create the cloud on the sheet ───
        using (Transaction t = new Transaction(doc, "Revision Clouds"))
            t.Start();
            RevisionCloud.Create(doc, sheet, rev.Id, curves);
            t.Commit();
        return Result.Succeeded;
    //  Helper: model → sheet via parametric crop-box coordinates
    private sealed class ParamMapper
        private readonly Transform _toLocal;   // model → crop-local
        private readonly XYZ       _minLoc;    // crop local min
        private readonly double    _wLoc;      // crop width  (local)
        private readonly double    _hLoc;      // crop height "
        private readonly Outline   _vpOutline; // viewport box on sheet
        private readonly ViewportRotation _rot;
        public ParamMapper(View v, Viewport vp)
            BoundingBoxXYZ crop = v.CropBox;
            if (crop == null || !v.CropBoxActive)
                throw new InvalidOperationException("View lacks an active crop box.");
            _toLocal  = crop.Transform.Inverse;
            _minLoc   = crop.Min;
            _wLoc     = crop.Max.X - crop.Min.X;
            _hLoc     = crop.Max.Y - crop.Min.Y;
            _vpOutline = vp.GetBoxOutline();
            _rot       = vp.Rotation;
        public XYZ ToSheet(XYZ modelPt)
            // 1) model → local crop coordinates
            XYZ loc = _toLocal.OfPoint(modelPt);
            // 2) parametric position inside crop
            double u = (loc.X - _minLoc.X) / _wLoc;   // 0 … 1
            double v = (loc.Y - _minLoc.Y) / _hLoc;
            // 3) viewport size
            double wSheet = _vpOutline.MaximumPoint.X - _vpOutline.MinimumPoint.X;
            double hSheet = _vpOutline.MaximumPoint.Y - _vpOutline.MinimumPoint.Y;
            // 4) map (u,v) to sheet, honour 90° rotations
            double sx, sy;
            switch (_rot)
                case ViewportRotation.None:
                    sx = u * wSheet;
                    sy = v * hSheet;
                    break;
                case ViewportRotation.Clockwise:
                    sx = v * wSheet;
                    sy = (1.0 - u) * hSheet;
                    break;
                case ViewportRotation.Counterclockwise:
                    sx = (1.0 - v) * wSheet;
                    sy = u * hSheet;
                    break;
                default:
                    throw new InvalidOperationException("Unsupported viewport rotation.");
            return new XYZ(
                _vpOutline.MinimumPoint.X + sx,
                _vpOutline.MinimumPoint.Y + sy,
                0);
    private static Revision GetLatestVisibleRevision(Document doc)
        return new FilteredElementCollector(doc)
               .OfClass(typeof(Revision))
               .Cast<Revision>()
               .Where(r => r.Visibility != RevisionVisibility.Hidden)
               .OrderByDescending(r => r.SequenceNumber)
               .FirstOrDefault();
rcrdzmmrmnn
Viewports have a method called GetProjectionToSheetTransform()
you can use this to transform the location to sheet coordinates. Maybe this is your case...
baleti3266
holy corn @rcrdzmmrmnn you are right, this updated code works now:
// CloudsToSheetTransform.cs
// Draws a revision cloud on the sheet around every element
// currently selected in the active view.
// Revit 2023+ (needs View.GetModelToProjectionTransforms and
//              Viewport.GetProjectionToSheetTransform)
using System;
using System.Linq;
public class CloudsToSheetTransform : IExternalCommand
  private const double OFFSET_MODEL = 0.20;   // ft – halo added in MODEL space
    ref string message,
    // 1) Ensure something is selected and the view is placed
    if (!selIds.Any())
    Viewport  vp    = null;
          sheet = sh;
          break;
    if (sheet == null)
      message = "The active view is not placed on any sheet.";
    // 2) Model → Sheet transform (native, loss-free)
    IList<TransformWithBoundary> tList = view.GetModelToProjectionTransforms();
    if (tList.Count == 0)
      message = "View has no model-to-projection transform.";
    // Use the METHOD – not a property
    Transform modelToProj  = tList[0].GetModelToProjectionTransform();
    Transform projToSheet  = vp.GetProjectionToSheetTransform();
    Transform modelToSheet = projToSheet.Multiply(modelToProj);
    // 3) Pick (or create) a visible revision
    Revision rev = new FilteredElementCollector(doc)
                  .Cast<Revision>()
                  .FirstOrDefault();
    if (rev == null)
        t.Start();
        t.Commit();
    // 4) Build sheet-space rectangles around each selected element
    var sheetCurves = new List<Curve>();
      // Expand model-space bounding box by OFFSET_MODEL
      XYZ min = bb.Min;
      XYZ max = bb.Max;
      min = new XYZ(min.X - OFFSET_MODEL, min.Y - OFFSET_MODEL, min.Z);
      max = new XYZ(max.X + OFFSET_MODEL, max.Y + OFFSET_MODEL, max.Z);
      // Four model-space corners (z irrelevant for 2-D projection)
      XYZ[] modelCorners =
        bb.Transform.OfPoint(new XYZ(min.X, min.Y, min.Z)),
        bb.Transform.OfPoint(new XYZ(min.X, max.Y, min.Z)),
        bb.Transform.OfPoint(new XYZ(max.X, max.Y, min.Z)),
        bb.Transform.OfPoint(new XYZ(max.X, min.Y, min.Z))
      // Transform to sheet and collect min/max in sheet coords
      double sxMin = double.PositiveInfinity, syMin = double.PositiveInfinity;
      double sxMax = double.NegativeInfinity, syMax = double.NegativeInfinity;
      foreach (XYZ mc in modelCorners)
        XYZ sp = modelToSheet.OfPoint(mc);
        sxMin = Math.Min(sxMin, sp.X);
        syMin = Math.Min(syMin, sp.Y);
        sxMax = Math.Max(sxMax, sp.X);
        syMax = Math.Max(syMax, sp.Y);
      // Four sheet-space rectangle lines (Z must be 0)
      XYZ bl = new XYZ(sxMin, syMin, 0);
      XYZ tl = new XYZ(sxMin, syMax, 0);
      XYZ tr = new XYZ(sxMax, syMax, 0);
      XYZ br = new XYZ(sxMax, syMin, 0);
      sheetCurves.Add(Line.CreateBound(bl, tl));
      sheetCurves.Add(Line.CreateBound(tl, tr));
      sheetCurves.Add(Line.CreateBound(tr, br));
      sheetCurves.Add(Line.CreateBound(br, bl));
    if (!sheetCurves.Any())
      message = "No bounding boxes found for the selection.";
    // 5) Create the revision cloud on the sheet
      t.Start();
      RevisionCloud.Create(doc, sheet, rev.Id, sheetCurves);
      t.Commit();
thanks a lot 🌽
baleti3266
I further refined the command to handle elevations/sections, prompt user to choose sheets if selected elements are not view-dependent or automatically choose views/sheets if they are and to prompt user to specify revision of these clouds:
revit-scripts/revit-scripts/DrawRevisionCloudAroundSelectedElements.cs at main · baleti/revit-script...
however, I couldn't get drafting views and legends yet to work, looks like they don't work with GetProjectionToSheetTransform and throw exception "The viewport does not have transforms."  @rcrdzmmrmnn if you had any suggestions how to handle them that would be again most appreciated
