Handling Errors
Handling Errors
PaulCollins7972
Handling Errors
PaulCollins7972
Hi
I am not quite sure how to solve and hide error messages genereated by copy/paste in API.
I have this which hides warning messages and deletes the elements causing an error,this works ok but still shows the error message to the user:
'suppress all warnings
For Each f As FailureMessageAccessor In failList
Dim fs As FailureSeverity = fa.GetSeverity
Select Case fs
Case FailureSeverity.Warning
'hide messages of severity "Warning"
fa.DeleteWarning(f)
Case FailureSeverity.Error
Dim elist As List(Of ElementId) = f.GetFailingElementIds
fa.DeleteElements(elist)
fa.ResolveFailure(f)
Return FailureProcessingResult.ProceedWithCommit
Case Else
Return FailureProcessingResult.ProceedWithRollBack
End Select
Next
This is called by the transaction options:
If t.Start() = TransactionStatus.Started Then
Dim FailOpt As FailureHandlingOptions = t.GetFailureHandlingOptions()
FailOpt.SetFailuresPreprocessor(New myFailurePreProcessor())
t.SetFailureHandlingOptions(FailOpt)
I have seen Jeremy's post  of May 7 2014 on handling warnings and failures and adapt the example c# code to vb as:
Private Sub DoFailureProcessing(sender As Object, args As Autodesk.Revit.DB.Events.FailuresProcessingEventArgs)
Dim failuresAccessor As FailuresAccessor = args.GetFailuresAccessor()
'failuresAccessor
Dim fmas As IList(Of FailureMessageAccessor) = failuresAccessor.GetFailureMessages()
If fmas.Count = 0 Then
args.SetProcessingResult(FailureProcessingResult.[Continue])
Return
For Each fma As FailureMessageAccessor In fmas
Dim id As FailureDefinitionId = fma.GetFailureDefinitionId()
failuresAccessor.ResolveFailure(fma)
Next
args.SetProcessingResult(FailureProcessingResult.ProceedWithCommit)
Return
End Sub
What I am struggling with is how to get the DoFailureProcessing code to be triggered?
(I am using Revit 2016, VS2012 and VBdotNet)
Any help appreciated
Paul
arnostlobel
What you need is to subscribe to FailuresProcessingEvent.
Keep in mind, though, that unlike the failure pre-processor, the event is raised for failures of all and every transaction no matter who made it. Thus it is probably a good idea to un-subscribe from the event when you applications stops being involved with mode changes.
By the way, you should only attempt resolving failures that are resolvable; Not every failure can be resolved.
Arnošt Löbel
augusto.goncalves
And check the \Revit 2016 SDK\Samples\ErrorHandling sample for more details.
Augusto Goncalves
Twitter @augustomaia
Autodesk Developer Network
