handling element before placement.
can i get element type before placement?
i expect below steps.
1. execute externcal command that shows modeless dialog.
2. execute draw pipe command.(waitting click two point.)
3. click the button in modeless dialog.
4. get pipe type information/parameter to draw.
5. change the pipe diameter parameter in modeless dialog.
6. pick two point, applied diameter pipe be created.
how can i solve this work?
jeremytammik
You can set the default type before actually placing the instance:
http://help.autodesk.com/view/RVT/2015/ENU/?guid=GUID-7E3AC667-86B1-4DDE-8812-C776C8929CF5
Revit 2015 introduced a Default Type API for that very purpose:
http://www.thebuildingcoder.typepad.com/blog/2014/04/whats-new-in-the-revit-2015-api.html#3.02
Cheers,
Jeremy
Jeremy Tammik
Developer Technical Services
The Building Coder
