Guid changes of IFC
Guid changes of IFC
Guid changes of IFC
If we Link IFC in Revit.
In the background revit makes a shared parameter file and a .rvt file of the IFC.
If we receive a new version and we re-link the file another shared parameter file is produced.
If we open the .txt file the original GUID of an object is changed.
So the shared parameter file can not be used.
For example
If we want to assign a hatch to the IFC we can use the shared parameter file.
But if the parameter is always changing we cannot build these hatch standard into our template.
What is the standard location of the shared parameter file Revit uses to create from the IFC?
jeremytammik
Dear Benjamin,
Thank you for your query.
The most effective place to discuss Revit API IFC issues is generally the Revit IFC open source discussion forum:
https://sourceforge.net/p/ifcexporter/discussion/general
You might want to ask your question there as well, in case other developers have run into the same issue in the past.
I'll gladly pass on your question to the development team, though, and add whatever insights I can glean from them here to this thread.
Best regards,
Jeremy
Jeremy Tammik
Developer Technical Services
The Building Coder
Where is the shared parameter file located?
Revit has to use a standard template of this shared parameter file?
And why Revit creates a new Revit model.ifc? Is there some logical explanation for?
jeremytammik
Dear Benjamin,
Thank you for your update.
One colleague suggested looking at the following method for retrieving an existing parameter definition, if it exists, or creating a new one, if not:
  /// <summary>
  /// Returns the ExternalDefinition to create a SharedParameter to add to a Revit document.
  /// </summary>
  /// <param name="doc">The document.</param>
  /// <param name="name">The parameter name.</param>
  /// <param name="groupName">The name of the group in the Shared Parmeter file.</param>
  /// <param name="type">The type.</param>
  /// <param name="visible">if set to <c>true</c> [visible].</param>
  /// <param name="userModifiable">if set to <c>true</c> [user modifiable].</param>
  /// <param name="cats">The cats.</param>
  /// <param name="group">The group.</param>
  /// <param name="inst">if set to <c>true</c> [inst].</param>
  /// <returns></returns>
  private ExternalDefinition RawCreateProjectParameter(Document doc, string name, string groupName, ParameterType type, bool visible, bool userModifiable, CategorySet cats, BuiltInParameterGroup group, bool inst)
    Log(name);
    ExternalDefinition def = null;
    DefinitionGroup defGroup = null;
    // (1) Check if the group exists in the Shared Parameters File
    foreach (DefinitionGroup dg in doc.Application.OpenSharedParameterFile().Groups)
      if (dg.Name == groupName)
        Log(string.Format("DefinitionGroup {0} found.", groupName));
        defGroup = dg;
        break;
    if (defGroup == null)
      defGroup = doc.Application.OpenSharedParameterFile().Groups.Create(groupName);
      Log(string.Format("DefinitionGroup {0} created.", groupName));
    // (2) Check if the external definition exists in the Shared Parameters File
    if (defGroup.Definitions.Cast<ExternalDefinition>().Where(x => x.Name == name).Count() > 0)
      Log(string.Format("Exploring definitions...", ""));
      foreach (ExternalDefinition ed in defGroup.Definitions.Cast<ExternalDefinition>())
        bool t1 = ed.Name == name;
        bool t2 = ed.ParameterType == type;
        bool t3 = ed.Visible == visible;
        bool t4 = ed.UserModifiable == userModifiable;
        //bool t5 = ed.ParameterGroup == group;
        if (t1 && t2 && t3 && t4)
          def = ed;
          Log(string.Format("ExternalDefinition {0} found.", name));
          break;
    if (def == null)
      Log(string.Format("Creating definition...", ""));
      ExternalDefinitionCreationOptions edco = new ExternalDefinitionCreationOptions(name, type);
      edco.UserModifiable = userModifiable;
      edco.Visible = visible;
      def = defGroup.Definitions.Create(edco) as ExternalDefinition;
      Log(string.Format("ExternalDefinition {0} created.", name));
    if (def == null)
      Log(string.Format("ExternalDefinition {0} is null.", name));
      return null;
// (3) Check if the external definition has been already bound to the categories in the category set CategorySet cs2 = new CategorySet(); try { BindingMap bm = doc.ParameterBindings; foreach (Category cat in cats) { // Loop all Binding Definitions // IMPORTANT NOTE: Categories.Size is ALWAYS 1 !? // For multiple categories, there is really one // pair per each category, even though the // Definitions are the same... DefinitionBindingMapIterator iter = doc.ParameterBindings.ForwardIterator(); bool found = true; while (iter.MoveNext()) { if (iter.Key.Name == name) { ElementBinding eb = (ElementBinding)iter.Current; foreach (Category catEB in eb.Categories) { if (catEB.Id.IntegerValue.Equals(cat.Id.IntegerValue)) { if (type == iter.Key.ParameterType) { if (group == iter.Key.ParameterGroup) { found = false; break; } } } } } } if (found) { cs2.Insert(cat); } } if (cs2.Size == 0) { Log(string.Format("The Parameter already exists.", cs2.Size)); } else { Log(string.Format("The Parameter will be bound to {0} categor{1}.", cs2.Size, cs2.Size == 1 ? "y" : "ies")); Autodesk.Revit.DB.Binding binding = doc.Application.Create.NewTypeBinding(cs2); if (inst) { binding = doc.Application.Create.NewInstanceBinding(cs2); } BindingMap map = doc.ParameterBindings; map.Insert(def, binding, group); Log(string.Format("Parameter bound successfully.", "")); } } catch (Exception ex) { Log(string.Format("ERROR Creating Shared Parameter: {0}", ex.Message)); } return def; }
I have not yet heard back from the true IFC experts, though...
Here are my two cents on your last two questions:
Yes.
It creates a new model.ifc.rvt file in order to create appropriate placeholder elements needed for the linking process.
Best regards,
Jeremy
Jeremy Tammik
The Building Coder
jeremytammik
The development team responds that this is a limitation for now, unfortunately, and add that it should read in the existing file and use that if it exists.
Jeremy Tammik
The Building Coder
