关于模型轻量化的问题(请求电话咨询 - xxx-xxxxxxxx)
根据目前的需求需要在浏览器加载大量模型操作,由于浏览器的特性和模型的体积原因,模型过大导致网页页面加载困难,需要对模型做出轻量化的手段解决问题;想请问有没有什么好的对模型进行轻量化的解决方案模型以及轻量化后如何通过API获取模型数据和属性,谢谢!
jeremytammik
Is this really a Revit API question?
According to Google translate, you ask:
"According to the current demand, a large number of model operations need to be loaded in the browser. Due to the characteristics of the browser and the volume of the model, the model is too large to load the webpage. Therefore, it is necessary to reduce the weight of the model and solve the problem. Would like to ask whether there is any Good model for lightweight solution model and how to get the model data and attributes through the API after light-weight, thanks!"
This sounds more like a Forge question than a Revit API related one to me.
If it is indeed Forge related, the right places to discuss this are listed here:
https://autodesk-forge.github.io > Resources > Get Help
This leads to:
https://developer.autodesk.com/en/support/get-help
Cheers,
Jeremy
Jeremy Tammik
Developer Technical Services
The Building Coder
