Grid Element Curve misbehavior?
Hi All,
I'm dealing with some issues with the curves geometry from the grid elements. In my code I asked to get te StartPoint and End Point for every grid to do some stuff later with the curve orientation.
I draw the grids like in the orientation as the following image:
The result I got is as follows:
As you can see in the schedule, the Start Point coordinates indicate that the curves were created in the opposite direction. Just to show in more detail the issue, I replicated the example in DYnamo and got the same conclusion:
So, I would like to know:
1.- What am I missing here?
2.- If I replicate this procedure with a wall element (for ex.) using the location of the wall, I get the coordinates according to the drawn orientation. So, Are grids working in a different way?
Thanks in advance for your help!
Cheers!
