GlobalParameter Create Error SpecTypeId (Revit 22.0.2.392)
ricaun
Advisor Advisor
ricaun
I was trying to create GlobalParameter using each SpecTypeId to validate my Extension and had some problems with some ForgeTypeId. Failed to create a new parameter's definition!
Here is my sample code that shows 16 SpecTypeId has this problem.
using Autodesk.Revit.Attributes;
using Autodesk.Revit.DB;
using Autodesk.Revit.UI;
using System;
namespace RevitAddin
    [Transaction(TransactionMode.Manual)]
    public class CommandGlobalError2022 : IExternalCommand
        public Result Execute(ExternalCommandData commandData, ref string message, ElementSet elementSet)
            UIApplication uiapp = commandData.Application;
            UIDocument uidoc = uiapp.ActiveUIDocument;
            Document document = uidoc.Document;
            var name = $"Global {DateTime.Now.Ticks}";
            string text = "";
            using (Transaction transaction = new Transaction(document))
                transaction.Start("GlobalParameter");
                foreach (var specTypeId in UnitUtils.GetAllSpecs())
                    try
                        var globalParameter = GlobalParameter.Create(document, name, specTypeId);
                        document.Delete(globalParameter.Id);
                    catch (Exception ex)
                        text += $"{specTypeId.TypeId}\n";
                        Console.WriteLine(ex);
                transaction.Commit();
            System.Windows.Clipboard.SetText(text);
            System.Windows.MessageBox.Show(text, $"GlobalParameter.Create Error | RevitBuild {document.Application.VersionBuild}");
            return Result.Succeeded;
I'm using Revit BuildVersion 22.0.2.392, I didn't test on the last HotFix version for Revit 2022.
Here are the 16 Forge TypeId that throws the error.
autodesk.spec.aec.electrical:costRateEnergy-2.0.0
autodesk.spec.aec.electrical:costRatePower-2.0.0
autodesk.spec.aec.electrical:powerPerLength-2.0.0
autodesk.spec.aec.energy:heatCapacityPerArea-2.0.0
autodesk.spec.aec.energy:isothermalMoistureCapacity-2.0.0
autodesk.spec.aec.energy:thermalGradientCoefficientForMoistureCapacity-2.0.0
autodesk.spec.aec.hvac:angularSpeed-2.0.0
autodesk.spec.aec.hvac:diffusivity-2.0.0
autodesk.spec.aec.hvac:flowPerPower-2.0.0
autodesk.spec.aec.hvac:massPerTime-2.0.0
autodesk.spec.aec.hvac:powerPerFlow-2.0.0
autodesk.spec.aec.infrastructure:stationingInterval-2.0.0
autodesk.spec.aec.piping:massPerTime-2.0.0
autodesk.spec.aec:costPerArea-2.0.0
autodesk.spec.aec:distance-2.0.0
autodesk.spec.aec:rotationAngle-2.0.0
The strange part is that I tested a similar code for SharedParameter and didn't have any errors.
See yaa!
Luiz Henrique Cassettari
ricaun.com - Revit API Developer
AppLoader EasyConduit WireInConduit ConduitMaterial CircuitName ElectricalUtils
jeremy_tammik
Thank you for the report. I'll pass it on to the powers that be.
jeremy_tammik
Dear Luiz Henrique,
Thank you for your report and clear description.
Sorry to hear about this.
I logged the issue REVIT-193493 [API Error creating global parameter with certain SpecTypeIds] with our development team for this on your behalf as it requires further exploration and possibly a modification to our software. Please make a note of this number for future reference.
You are welcome to request an update on the status of this issue or to provide additional information on it at any time quoting this change request number.
This issue is important to me. What can I do to help?
This issue needs to be assessed by our engineering team and prioritised against all other outstanding change requests. Any information that you can provide to influence this assessment will help. Please provide the following where possible:
  • Impact on your application and/or your development.
  • The number of users affected.
  • The potential revenue impact to you.
  • The potential revenue impact to Autodesk.
  • Realistic timescale over which a fix would help you.
  • In the case of a request for a new feature or a feature enhancement, please also provide detailed Use cases for the workflows that this change would address.
This information is extremely important. Our engineering team have limited resources, and so must focus their efforts on the highest impact items. We do understand that this will cause you delays and affect your development planning, and we appreciate your cooperation and patience.
Best regards,
Jeremy
ricaun
Hello Jeremy
I tested basically the same code using Revit 2023 and looks like every ForgeTypeId in the UnitUtils.GetAllMeasurableSpecs() create the GlobalParameter normally, including the 16 SpecTypeIds.
Here is the code:
using System;
namespace RevitAddin.Error.Revit.Commands
    public class CommandGlobalCreateTest2023 : IExternalCommand
            string text = "";
            int errorCount = 0;
                foreach (var specTypeId in UnitUtils.GetAllMeasurableSpecs())
                    var created = true;
                    try
                        errorCount++;
                        created = false;
                    text += $"{created}\t {specTypeId.TypeId}\n";
            text = $"Created\t ForgeTypeId\t Error:{errorCount}\n{text}";
 And here is the result in RevitBuild 23.0.1.318:
Created	 ForgeTypeId	 Error:0
True	 autodesk.spec.aec.electrical:apparentPower-2.0.0
True	 autodesk.spec.aec.electrical:apparentPowerDensity-1.0.0
True	 autodesk.spec.aec.electrical:cableTraySize-2.0.0
True	 autodesk.spec.aec.electrical:colorTemperature-2.0.0
True	 autodesk.spec.aec.electrical:conduitSize-2.0.0
True	 autodesk.spec.aec.electrical:costRateEnergy-2.0.0
True	 autodesk.spec.aec.electrical:costRatePower-2.0.0
True	 autodesk.spec.aec.electrical:current-2.0.0
True	 autodesk.spec.aec.electrical:demandFactor-2.0.0
True	 autodesk.spec.aec.electrical:efficacy-2.0.0
True	 autodesk.spec.aec.electrical:frequency-2.0.0
True	 autodesk.spec.aec.electrical:illuminance-2.0.0
True	 autodesk.spec.aec.electrical:luminance-2.0.0
True	 autodesk.spec.aec.electrical:luminousFlux-2.0.0
True	 autodesk.spec.aec.electrical:luminousIntensity-2.0.0
True	 autodesk.spec.aec.electrical:potential-2.0.0
True	 autodesk.spec.aec.electrical:power-2.0.0
True	 autodesk.spec.aec.electrical:powerDensity-2.0.0
True	 autodesk.spec.aec.electrical:powerPerLength-2.0.0
True	 autodesk.spec.aec.electrical:resistivity-2.0.0
True	 autodesk.spec.aec.electrical:temperature-2.0.0
True	 autodesk.spec.aec.electrical:temperatureDifference-2.0.0
True	 autodesk.spec.aec.electrical:wattage-2.0.0
True	 autodesk.spec.aec.electrical:wireDiameter-2.0.0
True	 autodesk.spec.aec.energy:energy-2.0.0
True	 autodesk.spec.aec.energy:heatCapacityPerArea-2.0.0
True	 autodesk.spec.aec.energy:heatTransferCoefficient-2.0.0
True	 autodesk.spec.aec.energy:isothermalMoistureCapacity-2.0.0
True	 autodesk.spec.aec.energy:permeability-2.0.0
True	 autodesk.spec.aec.energy:specificHeat-2.0.0
True	 autodesk.spec.aec.energy:specificHeatOfVaporization-2.0.0
True	 autodesk.spec.aec.energy:thermalConductivity-2.0.0
True	 autodesk.spec.aec.energy:thermalGradientCoefficientForMoistureCapacity-2.0.0
True	 autodesk.spec.aec.energy:thermalMass-2.0.0
True	 autodesk.spec.aec.energy:thermalResistance-2.0.0
True	 autodesk.spec.aec.hvac:airFlow-2.0.0
True	 autodesk.spec.aec.hvac:airFlowDensity-2.0.0
True	 autodesk.spec.aec.hvac:airFlowDividedByCoolingLoad-2.0.0
True	 autodesk.spec.aec.hvac:airFlowDividedByVolume-2.0.0
True	 autodesk.spec.aec.hvac:angularSpeed-2.0.0
True	 autodesk.spec.aec.hvac:areaDividedByCoolingLoad-2.0.0
True	 autodesk.spec.aec.hvac:areaDividedByHeatingLoad-2.0.0
True	 autodesk.spec.aec.hvac:coolingLoad-2.0.0
True	 autodesk.spec.aec.hvac:coolingLoadDividedByArea-2.0.0
True	 autodesk.spec.aec.hvac:coolingLoadDividedByVolume-2.0.0
True	 autodesk.spec.aec.hvac:crossSection-2.0.0
True	 autodesk.spec.aec.hvac:density-2.0.0
True	 autodesk.spec.aec.hvac:diffusivity-2.0.0
True	 autodesk.spec.aec.hvac:ductInsulationThickness-2.0.0
True	 autodesk.spec.aec.hvac:ductLiningThickness-2.0.0
True	 autodesk.spec.aec.hvac:ductSize-2.0.0
True	 autodesk.spec.aec.hvac:factor-2.0.0
True	 autodesk.spec.aec.hvac:flowPerPower-2.0.0
True	 autodesk.spec.aec.hvac:friction-2.0.0
True	 autodesk.spec.aec.hvac:heatGain-2.0.0
True	 autodesk.spec.aec.hvac:heatingLoad-2.0.0
True	 autodesk.spec.aec.hvac:heatingLoadDividedByArea-2.0.0
True	 autodesk.spec.aec.hvac:heatingLoadDividedByVolume-2.0.0
True	 autodesk.spec.aec.hvac:massPerTime-2.0.0
True	 autodesk.spec.aec.hvac:power-2.0.0
True	 autodesk.spec.aec.hvac:powerDensity-2.0.0
True	 autodesk.spec.aec.hvac:powerPerFlow-2.0.0
True	 autodesk.spec.aec.hvac:pressure-2.0.0
True	 autodesk.spec.aec.hvac:roughness-2.0.0
True	 autodesk.spec.aec.hvac:slope-2.0.0
True	 autodesk.spec.aec.hvac:temperature-2.0.0
True	 autodesk.spec.aec.hvac:temperatureDifference-2.0.0
True	 autodesk.spec.aec.hvac:velocity-2.0.0
True	 autodesk.spec.aec.hvac:viscosity-2.0.0
True	 autodesk.spec.aec.infrastructure:stationing-2.0.0
True	 autodesk.spec.aec.infrastructure:stationingInterval-2.0.0
True	 autodesk.spec.aec.piping:density-2.0.0
True	 autodesk.spec.aec.piping:flow-2.0.0
True	 autodesk.spec.aec.piping:friction-2.0.0
True	 autodesk.spec.aec.piping:mass-2.0.0
True	 autodesk.spec.aec.piping:massPerTime-2.0.0
True	 autodesk.spec.aec.piping:pipeDimension-2.0.0
True	 autodesk.spec.aec.piping:pipeInsulationThickness-2.0.0
True	 autodesk.spec.aec.piping:pipeMassPerUnitLength-2.0.0
True	 autodesk.spec.aec.piping:pipeSize-2.0.0
True	 autodesk.spec.aec.piping:pressure-2.0.0
True	 autodesk.spec.aec.piping:roughness-2.0.0
True	 autodesk.spec.aec.piping:slope-2.0.0
True	 autodesk.spec.aec.piping:temperature-2.0.0
True	 autodesk.spec.aec.piping:temperatureDifference-2.0.0
True	 autodesk.spec.aec.piping:velocity-2.0.0
True	 autodesk.spec.aec.piping:viscosity-2.0.0
True	 autodesk.spec.aec.piping:volume-2.0.0
True	 autodesk.spec.aec.structural:acceleration-2.0.0
True	 autodesk.spec.aec.structural:areaForce-2.0.0
True	 autodesk.spec.aec.structural:areaForceScale-2.0.0
True	 autodesk.spec.aec.structural:areaSpringCoefficient-2.0.0
True	 autodesk.spec.aec.structural:barDiameter-2.0.0
True	 autodesk.spec.aec.structural:crackWidth-2.0.0
True	 autodesk.spec.aec.structural:displacement-2.0.0
True	 autodesk.spec.aec.structural:energy-2.0.0
True	 autodesk.spec.aec.structural:force-2.0.0
True	 autodesk.spec.aec.structural:forceScale-2.0.0
True	 autodesk.spec.aec.structural:frequency-2.0.0
True	 autodesk.spec.aec.structural:lineSpringCoefficient-2.0.0
True	 autodesk.spec.aec.structural:linearForce-2.0.0
True	 autodesk.spec.aec.structural:linearForceScale-2.0.0
True	 autodesk.spec.aec.structural:linearMoment-2.0.0
True	 autodesk.spec.aec.structural:linearMomentScale-2.0.0
True	 autodesk.spec.aec.structural:mass-2.0.0
True	 autodesk.spec.aec.structural:massPerUnitArea-2.0.0
True	 autodesk.spec.aec.structural:massPerUnitLength-2.0.0
True	 autodesk.spec.aec.structural:moment-2.0.0
True	 autodesk.spec.aec.structural:momentOfInertia-2.0.0
True	 autodesk.spec.aec.structural:momentScale-2.0.0
True	 autodesk.spec.aec.structural:period-2.0.0
True	 autodesk.spec.aec.structural:pointSpringCoefficient-2.0.0
True	 autodesk.spec.aec.structural:pulsation-2.0.0
True	 autodesk.spec.aec.structural:reinforcementArea-2.0.0
True	 autodesk.spec.aec.structural:reinforcementAreaPerUnitLength-2.0.0
True	 autodesk.spec.aec.structural:reinforcementCover-2.0.0
True	 autodesk.spec.aec.structural:reinforcementLength-2.0.0
True	 autodesk.spec.aec.structural:reinforcementSpacing-2.0.0
True	 autodesk.spec.aec.structural:reinforcementVolume-2.0.0
True	 autodesk.spec.aec.structural:rotation-2.0.0
True	 autodesk.spec.aec.structural:rotationalLineSpringCoefficient-2.0.0
True	 autodesk.spec.aec.structural:rotationalPointSpringCoefficient-2.0.0
True	 autodesk.spec.aec.structural:sectionArea-2.0.0
True	 autodesk.spec.aec.structural:sectionDimension-2.0.0
True	 autodesk.spec.aec.structural:sectionModulus-2.0.0
True	 autodesk.spec.aec.structural:sectionProperty-2.0.0
True	 autodesk.spec.aec.structural:stress-2.0.0
True	 autodesk.spec.aec.structural:surfaceAreaPerUnitLength-2.0.0
True	 autodesk.spec.aec.structural:thermalExpansionCoefficient-2.0.0
True	 autodesk.spec.aec.structural:unitWeight-2.0.0
True	 autodesk.spec.aec.structural:velocity-2.0.0
True	 autodesk.spec.aec.structural:warpingConstant-2.0.0
True	 autodesk.spec.aec.structural:weight-2.0.0
True	 autodesk.spec.aec.structural:weightPerUnitLength-2.0.0
True	 autodesk.spec.aec:angle-2.0.0
True	 autodesk.spec.aec:area-2.0.0
True	 autodesk.spec.aec:costPerArea-2.0.0
True	 autodesk.spec.aec:decimalSheetLength-2.0.0
True	 autodesk.spec.aec:distance-2.0.0
True	 autodesk.spec.aec:length-2.0.0
True	 autodesk.spec.aec:massDensity-2.0.0
True	 autodesk.spec.aec:number-2.0.0
True	 autodesk.spec.aec:rotationAngle-2.0.0
True	 autodesk.spec.aec:sheetLength-2.0.0
True	 autodesk.spec.aec:siteAngle-2.0.0
True	 autodesk.spec.aec:slope-2.0.0
True	 autodesk.spec.aec:speed-2.0.0
True	 autodesk.spec.aec:time-2.0.0
True	 autodesk.spec.aec:volume-2.0.0
True	 autodesk.spec.measurable:currency-2.0.0
The idea was to stop the problem to go to the next version, I don't know if this report influenced but looks like was fixed in Revit 2023.
My application does not use any of these SpecTypeIds in GlobalParameter, but I use some of the most common parameter types (Text, Integer, YesNo). If this was this type probably gonna annoying me.
Everything is fine so! Thanks for the response, Jeremy!
jeremy_tammik
Thank you for the updated test and confirmation. Glad to hear that it works now.
piotr.choromanski
Observer
Observer
Hi there.Thanks for this topic. Is there a ForgeID for the YesNo parameter?
ricaun
Here are the four basic SpecTypeId (bool, int, string, double)
