Revit API Forum
Welcome to Autodesk’s Revit API Forums. Share your knowledge, ask questions, and explore popular Revit API topics.
Getting the multiple element IDs for materials in a wall
5 REPLIES 5
1341 Views, 5 Replies
I am trying to get a list of the materials that are contained within each wall type. Ideally I would like the names but as a start I am just trying to get the material IDs. I am using the following code (adapted from the Revit Intro Lab 1) where I iterate through the wall types and have a sub-routine to iterate through the materialIds of each WallType. Using this code it seems that the sub-foreach routine is not working and the string p that I create is left unfilled. Any advice would be much appreciated.
        FilteredElementCollector wallTypes // 2014
          = new FilteredElementCollector(rvtDoc)
            .OfClass(typeof(WallType));
        string s = "";
        foreach (WallType wallType in wallTypes)
string p = ""; foreach (ElementId mat3 in wallType.GetMaterialIds(false)) { p += mat3.ToString() + "\r\n"; } s += wallType.Name + p + "\r\n"; } // Show the result: TaskDialog.Show( "Revit Intro Lab", "Wall Types (in main instruction):\n\n" + s);
Tags (1)
5 REPLIES 5
GonçaloFeio1321
Try this:
public IEnumerable<Material> Get(WallType wallType)
if (wallType== null)
throw new ArgumentNullException(nameof(wallType));
var document = wallType.Document; var layers = wallType.GetCompoundStructure().GetLayers(); foreach (var layer in layers) { var materialId = layer.MaterialId; if (materialId != ElementId.InvalidElementId) { yield return document.GetElement(layer.MaterialId) as Material; } } }
The Element GetMaterialIds method works only for model instances, not their types.
Edit: Added a nice check for null
in reply to: GonçaloFeio1321
Thanks for your reply. I have tried implementing your Get() method as follows:
string s = "";
s += Get(wallType) + "\r\n";
TaskDialog.Show(
          "Revit Intro Lab",
However when I print the result to dialog I get the following message:
"Material_Select_2 + <Get>d__0" for each instance
Material_Select_2 is the name of my class, I am guessing this has something to do with the variable it is stored in, do you have any idea how I can convert this to a string?
GonçaloFeio1321
The Get method returns a IEnumerable<Material>, even duplicates. And you are just adding that to the string.
Try replacing the line s += Get(wallType) + "\r\n"; wih this:
foreach (var material in Get(wallType))
    builder.AppendLine($"Material: {material.Name}");
Thanks again for your reply. I incorporated this method and now the code is generating this error " System.NullReferenceException: Object reference not set to an instance of an object . at Material_Select_2.<Get>d__0.MoveNext()"
I tried to incorporate an exception, as you can see below, but I am still getting the same error:
StringBuilder builder = new StringBuilder();
        string s = "";
                if (material == null)
                    throw new ArgumentNullException(nameof(material));
GonçaloFeio1321
Allan, here is the refactored method.
public Result Execute(ExternalCommandData commandData, ref string message, ElementSet elements)
    var uiDoc = commandData.Application.ActiveUIDocument;
    var rvtDoc = uiDoc.Document;
    using (var collector = new FilteredElementCollector(rvtDoc))
        using (var filtered = collector.OfClass(typeof(WallType)))
            var builder = new StringBuilder();
            foreach (var wallType in filtered.OfType<WallType>())
                if (wallType.Kind == WallKind.Basic)
                    builder.AppendLine($"WallType: {wallType.Name}");
            TaskDialog.Show("Output", builder.ToString());
    return Result.Succeeded; // Why Failed?
Forma Design Contest
Rail Community
