Getting the Family Instance Geometry Curves Boundary Using C#
ahmadkhalaf7892
ahmadkhalaf7892
Hi Everyone I wanted to ask if I had a family instance in C# And I want to get the curves of it how can I achieve that using C#?
For example in the below picture you can see some red Lines, I wanted to ask how can I get these red lines as a curve from a family instance using the Revit ApI. I would appreciate any method or a way to help me get through it .
All I need is to obtain the boundary curves from a familyinstance or an element .
Mohamed_Arshad
Hi @ahmadkhalaf7892
  There is no direct method to get the edge loop.  You can use get_Geometry() method and iterate the geometry to get the particular face. Kindly refer the below code for additional reference.
Reference Code:
            Options opt = new Options();
            opt.ComputeReferences = true;
            opt.DetailLevel = ViewDetailLevel.Fine;
            //Pass Family Instance to this method
            GeometryElement geoElem = element.get_Geometry(opt);
            //For Family Instance we neec Iterate for again into InstanceGeometry
            foreach (GeometryInstance inst in geoElem)
                GeometryElement elem = inst.GetInstanceGeometry(Transform.Identity);
                //In Sometime if it is a Nested Family Need to Iterate again for the InstanceGeometry
                foreach (GeometryObject obj in elem)
                    if (obj is Solid && (obj as Solid).SurfaceArea != 0)
                        Solid solid = obj as Solid;
                        FaceArray faceArray = solid.Faces;
                        foreach (Face face in faceArray)
                            //Get the Edge of Face which you needed
                            List<CurveLoop> edgeLoop = face.GetEdgesAsCurveLoops().ToList();
Hope this Helps 🙂
Mohamed Arshad K
Software Developer (CAD & BIM)
jeremy_tammik
The Building Coder shares several different examples illustrating different approaches, e.g.,
