Getting Property of Element Type
Hi, it's me again 🙂
I'm wondering how i can achieve the fact to acces to the type of a element property.
I'm getting a list of Element by :
m_elementsToProcess = collector.OfCategory(BuiltInCategory.OST_Roofs).WhereElementIsNotElementType().ToElements();
I didn't found something in the SDK sample, neither online, i dont' know if my process is wrong..
Could you help me ?
But i don't kno
PS :
I mean this property :
[url=https://www.noelshack.com/2018-25-1-1529324956-propertytype.png][img]https://image.noelshack.com/min...]
You can get element properties by using the following code
foreach(ElementId eid in m_elementsToProcess)
                        Element e = doc.GetElement(eid);
                        foreach(Parameter p in e.Parameters)
                            s = s + p.Definition.Name + "   " + p.AsValueString() + "\n";
                        TaskDialog.Show("points", s);
and if you want to change the value of the parameter
foreach (Parameter p in e.Parameters)
                            if(p.Definition.Name=="Slope")
                                p.SetValueString("18");
Hi !
Thanks for reply.
Sorry, I think i didn't explain my issue clearly.
When I use your code, i'm getting the property of the element of my document.
But here, i want to get the property of the type of this element 🙂
Maxence
try using this code
                        Element et = e.Document.GetElement(e.GetTypeId());
                        foreach(Parameter p in et.Parameters)
Hi !
I just figured out by myself (reading a post online)
Thanks for help anyway !
private void test(Element e)
                //ParameterSet parameters = e.Parameters;
                ElementType et = m_doc.GetElement(e.GetTypeId()) as ElementType;
                ParameterSet parameters = et.Parameters;
                StringBuilder sb = new StringBuilder();
                foreach (Parameter param in parameters)
                    if (param.Definition.Name == "Code composant_PA")
                        sb.AppendFormat("{0}  -  {1}\n", param.Definition.Name, param.AsValueString());
                TaskDialog.Show("points", sb.ToString());
I tryed get value using p.AsValueString(), but returned null, but here works with p.AsString() on Revit 2021
