getting keynote parameter issue
wahedfazeli
wahedfazeli
i want to get all keynotes of elements of my project i write this code but i dont know why this create error in my revit i want to transfer it to excel.
row=2;
foreach(Element e in new FilteredElementCollector(doc).OfClass(typeof(Wall)))
ElementType elem = doc.GetElement(e.Id) as ElementType;
Parameter p = elem.get_Parameter(BuiltInParameter.KEYNOTE_PARAM);
sheet.Cells[row, 4].Value = p.ToString();
row++;;
FAIR59
the line to get the walltype isn't correct. Use this instead
ElementType elem = doc.GetElement(e.GetTypeId()) as ElementType;
You might want to rethink your code. By collecting wall instances, you get the same walltype (and keynote value) multiple times.
You can get all the defined walltypes in the document like this:
			ElementMulticategoryFilter wallfilter =
				new ElementMulticategoryFilter(new List<BuiltInCategory>(){BuiltInCategory.OST_Walls,BuiltInCategory.OST_StackedWalls});
			IEnumerable<ElementType> walltypes = new FilteredElementCollector(doc)
				.WhereElementIsElementType()
				.WherePasses(wallfilter)
				.Cast<ElementType>();
wahedfazeli
Thanks for your solution
But i want to put all keynotes parameters in every cells of excel
I should use for or foreach loop to get every keynote parameter and use it
I dont use transaction .can it be my problem?
Thank you
FAIR59
As you only read the document, you don't need a transaction.
this is the corrected code:
				sheet.Cells[row, 4].Value = p.AsString();
				row++;;
