GetSubComponentIds cannot get nested familyInstance information
I use this  family file, it has nested lamp, however, I use the follow code to get the nested lamp information.
ICollection<ElementId> subElemSet = familyinstance.GetSubComponentIds();
However, the problem is that subElemSet.count == 0, why I cannot get the lamp information from this family file?
Is there any other way to get the lamp information?
GetSubComponentIds() method works for nested families that are shared.
The "doc.EditFamily(famElement)" would get you the desired results.
Here's Jeremy's example:
http://thebuildingcoder.typepad.com/blog/2014/09/modifying-saving-and-reloading-families.html
Code copied from blog post:
Document doc = commandData.Application
    .ActiveUIDocument.Document;
  FilteredElementCollector collectorUsed
    = new FilteredElementCollector( doc );
  collectorUsed.OfClass( typeof( Family ) );
  foreach( Family f in collectorUsed )
    string name = f.Name;
    Document famdoc = doc.EditFamily( f );
    FilteredElementCollector famcollectorUsed
      = new FilteredElementCollector( famdoc );
    ICollection<ElementId> textNoteTypes
      = famcollectorUsed.OfClass( typeof( TextNoteType ) )
        .ToElementIds();
    foreach( ElementId textNoteTypeId in textNoteTypes )
      Element ele = doc.GetElement( textNoteTypeId );
      foreach( Parameter p in ele.Parameters )
        if( p.Definition.Name == "Text Font" )
          using( Transaction tranew
            = new Transaction( doc ) )
            tranew.Start( "Update" );
            p.Set( "Arial Black" );
            tranew.Commit();
