.GetLinkDocument() returns 'None'
adkaJK5HX
adkaJK5HX
Hello!
I try to get the linked document, however when Im applying GetLinkDocument() method on revit link instance it returns 'none'
jeremy_tammik
This looks like a typical example of a trusting human assuming and hoping that a computer will do what they think it should do, and not what they tell it to do. As far as I can see from your screen snapshot, your code looks like this:
81 linked_doc = link. GetLinkDocument()
82 print(link, linked doc)
You initialise a variable with an underscore, linked_doc.
Then, in the call to print, you list two separate new uninitialised variables, linked and doc.
They are both null, of course.
adkaJK5HX
Thank you for the reply, but there is an underscore - it was just hidden under the green line I have used to highlight the variable. If I would try to print a variable that is not defined, I would get just an error.
jeremy_tammik
Oh, sorry. One danger of posting screen snapshots instead of source code text...
jeremy_tammik
Taking another look, I must mention that ToElements()[0] is potentially a lot more expensive than FirstElement()...
jeremy_tammik
Sorry, I see no obvious reason for the None return.
